TBSS Throttle Body Problem
Old Jan 6, 2010 | 09:13 AM
truckmann's Avatar
Default TBSS Throttle Body Problem
Looking for a good deal on one let me know what you have.
Old Jan 6, 2010 | 08:29 PM
truckmann's Avatar
bump....
Old Jan 8, 2010 | 02:18 PM
truckmann's Avatar
Having issues with the TBSS TB I have. Hoping a car TB will work better and hoping to find one I don't have to go broke to buy.
Old Jan 8, 2010 | 02:21 PM
Atomic's Avatar
I have a gauge for that
Pardon my ignorance, but whats the difference? The TBSS has the LS2...
Old Jan 8, 2010 | 02:28 PM
truckmann's Avatar
The truck throttle body is a different design than the car throttle body. The truck one is actually 87mm and the car is 90mm. Not a big difference, but my problem is that apparently the truck style doesn't always play well with the X-harness possibly due to the way it's built. I'm getting a P1516 code at WOT that I believe is due to the TB I have and I'm hoping the car style will fix that.
Here are pictures https://www.performancetrucks.net/fo...0&postcount=24
Originally Posted by DrX
Maybe not on a blow-through application, but there are some other differences. The truck style TB is 87mm only at the widest points on the flange, or at its center.
Old Jan 8, 2010 | 08:52 PM
truckmann's Avatar
bump....
Old Jan 8, 2010 | 09:23 PM
Atomic's Avatar
Dont mean to jack your thread but isnt the only car the ls2 came in was the corvette?
Old Jan 8, 2010 | 09:30 PM
truckmann's Avatar
No problem. The same TB was in a few different cars including the GTO, G8 and the corvette. The LS7, LS2, L76, LS3, and L98 all use the same car style throttle body.
Old Jan 8, 2010 | 09:47 PM
chevydeth's Avatar
did you tune your truck to work with the throttle body?
Old Jan 8, 2010 | 09:53 PM
truckmann's Avatar
Other than a small adjustment to help idle learn quicker there really isn't any tuning that needs to be done for operation of the larger TB. The x-link takes care of it.
I have made some additional VE and idle airflow adjustments, but they are minor and are not tied to the P1516 code problem.
I think I'll double check that the TB I have isn't binding up in anyway. Maybe even take it apart and check it out before spending money on the car style.
