TBSS intake swap bolt question
Old Feb 11, 2010 | 04:10 PM
Ascinder's Avatar
Default TBSS intake swap bolt question
I am doing the TBSS intake swap onto L92 heads on my LQ4. The intake came with new intake manifold bolts. I am looking at these L92 bolts, and my old truck intake bolts and the older truck bolts have rubber isolators under the heads. The washer area is a little bigger than the new bolts also. I am just wondering if these new bolts were supposed to have the isolators on them or not. Here are some pics about what I am talking about. Also, does anyone have a part number for these new bolts, I lost one. Do you think I could just use one of the older truck intake bolts as a substitute?
PICT0991.jpg?t=1265926096
PICT0994.jpg?t=1265926134
PICT0995.jpg?t=1265926167
Old Feb 11, 2010 | 05:10 PM
JDC's Avatar
JDC
L92 heads are square port and TBSS intake is cathedral. wont work!
Coban's Avatar
TBSS Intake = cathedral ports
L92 Heads = rectangular ports...
Old Feb 11, 2010 | 06:35 PM
Ascinder's Avatar
Sorry, I guess I assumed it was a TBSS intake based on what I'd heard. It is a 2009 truck intake with the square ports. It is significantly bigger than the old 2004 truck intake I took off. It's rectangle ports on rectangle ports, everything lines up perfectly. The issue is just whether or not I can use the old bolts, and if I need to swap over the rubber isolators, thanks.
Old Feb 11, 2010 | 07:01 PM
JDC's Avatar
JDC
Im not sure on that. I just looked at my TBSS intake and the bolts that came with it dont have the rubbers either and the 6.0 intake I have does but they dont seem to come off the bolt.
Old Feb 11, 2010 | 07:42 PM
Ascinder's Avatar
Cool, thanks, I think I'll just pull the rubber piece off one of the old bolts and use it. I can just grind some lip off of the washer are so it fits.
Old Feb 11, 2010 | 07:44 PM
02'Z71ONDUBZ''s Avatar
Have you tried pulling up the schematics for an 09' truck intake assembly off gmpartsdirect.com to see if they show rubber washers on the assembly? I think that might answer your question but don't have time to look lol
Old Feb 11, 2010 | 08:14 PM
Ascinder's Avatar
Nothing's listed. Thanks for the tip though.
OHsixLS3
Dec 27, 2016 09:30 AM
04450r
Jul 24, 2015 01:58 AM
fat tony157
Jul 16, 2015 12:35 PM
4B11T
Jul 13, 2015 03:48 PM
Deceptarado
Jul 8, 2015 05:24 PM
