TBSS intake swap on 03 LQ9 6.0
Old Nov 10, 2015 | 06:50 PM
genxhunter's Avatar
Default TBSS intake swap on 03 LQ9 6.0
I'm doing a TBSS/NNBS intake swap (pn 25383922) on my 03 escalade ext LQ9 6.0. I have done a similar swap before but it was on a newer model truck (06 model). This truck uses a fuel rail with a regulator on it and return line. I am having the intake ported right now but have not found a fuel rail that will be tall enough to clear the new style 87mm intake. I already have the TB on my current intake using an X-link and an adapter plate (3 bolt to 4 bolt). Does anyone make a fuel rail that will work or do I have to resort to modifying my original one? Are there any other things I need to consider with this swap? What about taller injectors with the same connector? Any help would be greatly appreciated.
Old Nov 10, 2015 | 07:34 PM
Tim94gt's Avatar
12 Second Club
You can use the TBSS/NNBS rail with a corvette fuel filter. The vette filter has an internal regulator and works with return style fuel systems.
https://www.performancetrucks.net/fo...ll-nbs-493269/
Old Nov 11, 2015 | 06:43 AM
genxhunter's Avatar
Thanks for the response. Do you know the part number of the corvette filter? Does it regulate the fuel pressure to the same as the 03 LQ9? I know the 06 and newer GM trucks run at a little higher fuel pressure. Just wondering if it would be beneficial to bump mine up?
Old Nov 11, 2015 | 12:02 PM
Tim94gt's Avatar
12 Second Club
Not sure on the pressure, it's probably the same or slightly higher than stock. Not something I'd worry about though.
GM Part # 19239926
Old Nov 11, 2015 | 01:50 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It's regulated at 58 PSI.
Old Nov 11, 2015 | 09:07 PM
genxhunter's Avatar
That works for me. Thanks for the info.
Old Nov 11, 2015 | 09:35 PM
Wolftrk99's Avatar
Wix makes the filter 33737 is their pn
Old Nov 11, 2015 | 09:37 PM
Wolftrk99's Avatar
I have 58psi at idle at fuel test port after the filter/regulator......
Old Nov 11, 2015 | 09:40 PM
Wolftrk99's Avatar
An idea on how to connect it
Old Nov 11, 2015 | 09:43 PM
GMCtrk's Avatar
you can seriously have hooked up that rubber hose like that
