TBss intake and passenger valve cover hose location??
Hey guys I am running a elderbrock 90mm TB on my tbss intake, I don't know where I should put this h
ose since there is nowhere on the TB to install it.
I just have it plugged for now...
It needs to go somewhere since that's the fresh air supply to the block for the PCV system. Otherwise you could be putting a vacuum on the block and hurting the seals and sucking in excessive blowby. Put a small filter on it, or you can run it to your intake tubing post-MAF.
Noah Burns
09-07-2015 05:50 PM
low2001gmc
07-21-2015 02:09 PM
