TBss intake and passenger valve cover hose location??
Old 03-19-2013, 12:01 PM
WhiteChevy3's Avatar
Default TBss intake and passenger valve cover hose location??
Hey guys I am running a elderbrock 90mm TB on my tbss intake, I don't know where I should put this h
ose since there is nowhere on the TB to install it.
I just have it plugged for now...
Old 03-19-2013, 12:23 PM
Ferocity02's Avatar
It needs to go somewhere since that's the fresh air supply to the block for the PCV system. Otherwise you could be putting a vacuum on the block and hurting the seals and sucking in excessive blowby. Put a small filter on it, or you can run it to your intake tubing post-MAF.
Old 03-19-2013, 05:28 PM
Thanks for the reply Ferocity!
Old 03-19-2013, 06:06 PM
MASS seller approved
Petey62782's Avatar
I have the same intake and throttle body and I ran the tube to a barbed fitting setup on my K&N intake tube( after mass obviously ) and has been running great!
The_W
10-28-2015 09:00 PM
Noah Burns
09-07-2015 05:50 PM
04450r
07-24-2015 01:58 AM
Ammadien
07-22-2015 08:50 PM
low2001gmc
07-21-2015 02:09 PM
Quick Reply: TBss intake and passenger valve cover hose location??
