TBss intake and passenger valve cover hose location??
1 Attachment(s)
Hey guys I am running a elderbrock 90mm TB on my tbss intake, I don't know where I should put this h
ose since there is nowhere on the TB to install it. I just have it plugged for now... Attachment 118923 |
It needs to go somewhere since that's the fresh air supply to the block for the PCV system. Otherwise you could be putting a vacuum on the block and hurting the seals and sucking in excessive blowby. Put a small filter on it, or you can run it to your intake tubing post-MAF.
Thanks for the reply Ferocity!
I have the same intake and throttle body and I ran the tube to a barbed fitting setup on my K&N intake tube( after mass obviously ) and has been running great!
