TBSS Engine Swap Ideas
Old Sep 13, 2009 | 12:45 AM
OneBadLS's Avatar
Default TBSS Engine Swap Ideas
I don't own the truck yet, but considering getting one, I know they come stock with a LS2, I am just curious to see what kind of swaps I could do to this, I know alot of F-body Guys etc, do LSx Swaps amongst other things.
Would it be worth it to swap in a LS3 or to just get a LSx, I know some will mention the LQ9 because its a Cast Iron LS block basically.
I really have no idea what I should do, I want it to be a 10-11 sec truck, I know its possible I've seen a guy swap in a LSx Built motor and ran 9 something with it.
Old Sep 13, 2009 | 08:16 AM
krambo's Avatar
What is your budget and just how reliable do you want it to be? An 11 sec TBSS isn't that difficult to build and IMHO, the LS2 is just fine for that. I wouldn't spend money on swapping motors (depending on what you are looking for) just to run 11's.
Old Sep 13, 2009 | 06:47 PM
L7 Sierra's Avatar
It is possable as the LS series motors are quite cheap to modify and when the right parts are chosen respond very well in return.
Any GM truck based vehicle to get into the 11's needs alot work to it besides the Motor to be anywhere near reliable.
The TBSS has a 4L70 which should be built to level 5 specs as from what I hear a 4L80 requires surgury to fit. You'll also need a loose convertor 3600rpm stall, full exhaust, CAI depending on how you want to add power, and atleast 4.11 gearset with a detroit locker or maybe 2 if you have AWD.
I would take care of the weak links before looking for the big power or you will end up stranded. I have a rcsb and its weight detered me from big power till have I have the money to do everything. As I drive my truck everyday I need reliability over sheer power.
Old Sep 13, 2009 | 07:35 PM
OneBadLS's Avatar
I wanna be able to out perform or at least keep up with vettes, cobras built f-bodies etc. I could always go with a 402 stroker kit. or just swap in a LS3 and make that into a 427.
Old Sep 14, 2009 | 07:06 PM
03 BLACKOUTSSS's Avatar
you can do alot of things, how big is your wallet?
Old Sep 14, 2009 | 07:31 PM
OneBadLS's Avatar
ha ha, I am just throwing around ideas right now that's all. there are other vehicles I am considering.
Old Sep 14, 2009 | 07:39 PM
BOSS302's Avatar
Personally:
Stock LS2 +
GT7 Cam
TVS 2300
Meth
75 Shot NO2
Built Trans, rear-end, etc...
Old Sep 14, 2009 | 07:42 PM
v8envy's Avatar
first trick is getting a 14 second truck thats the first step
Old Sep 15, 2009 | 07:34 PM
OneBadLS's Avatar
Ha true, but these things can run 12-13's no problem.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
lxcoupe
Jul 14, 2015 10:14 PM
Nimoryan
Jul 5, 2015 03:50 PM
