tail pipe question
Old May 8, 2009 | 04:15 PM
sonoma43's Avatar
Default tail pipe question
what are the pros/cons of running a tail pipe compared to just having it dumped right after the muff? does one reduce rasp better than the other?
I did search too...didnt find anything quite like this
Old May 8, 2009 | 05:00 PM
BlackGMC's Avatar
Resident Retard
When i had mine dumped at the muffler it was tooooo loud on the inside of the truck, with the tailpipe it does not get tooo loud in the cab...
Old May 8, 2009 | 05:10 PM
sonoma43's Avatar
you think it would change being raspy at all? recently changed my muffler out and now there is some bad rasp between 28-3300 or so part throttle or wide open. just curious if the stock tail pipe would choke it up enough, that if I cut it off it would help. setup is lt's into ORY then factory pipe to a 3" bullet then factory tailpipe.
I know its going to have rasp just seeing if I could eliminate some off it.
GXPJAY
Feb 13, 2022 08:15 AM
Zack R
Aug 3, 2015 06:02 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
