Supercharging the Z06
Old Sep 17, 2004 | 05:26 PM
  #61
Flyer's Avatar
Vision, yes, that's correct. Although, it won't drop it by much if it's a true LS6.
Here's a good reason to pass on your 7k engine:
https://ls1tech.com/forums/showthread.php?t=217145
Old Sep 17, 2004 | 07:09 PM
  #62
Z06_Truck's Avatar
How much would the head swap drop the compression? How well do the Vortech heads compare to the LS6 heads? By the way it is in fact a true LS6 405 hp engine out of a new Vette.
Old Sep 18, 2004 | 11:51 AM
  #63
tooquick2beslo's Avatar
I have a question. This is a little off topic but O well.
Will the accesories from a 2001 silverado bolt right up to a Z06 motor ?
Also will the fuel rails work off of a 2001 silverado ?
Thanks for any help.
Old Sep 18, 2004 | 01:10 PM
  #64
Scream's Avatar
MOOBIES Moderator
Accessories? Yes.
To run the car intake, you have to re-wire your injector harness to accept the different injectors that the cars use, and also some spacers. Check the FAQ tech sticky in the performance section here in the truck section for a good how-to.
Old Sep 18, 2004 | 02:16 PM
  #65
Originally Posted by Scream
Accessories? Yes.
What if i wanted to run the truck intake and fuel rails will it work ?
Old Sep 18, 2004 | 02:43 PM
  #66
Scream's Avatar
MOOBIES Moderator
That's what I did. LS1 w/ truck accessories, intake manifold and exhaust manifolds. All you're doing is swapping out the longblock assembly.
moregrip
Jul 26, 2016 11:21 AM
5speedsilverado
Sep 25, 2015 06:50 PM
bagged7104SS
Sep 24, 2015 08:42 PM
Closer_2001
Sep 7, 2015 09:40 PM
