Supercharging the Z06
#61
Vision, yes, that's correct. Although, it won't drop it by much if it's a true LS6.
Here's a good reason to pass on your 7k engine:
https://ls1tech.com/forums/showthread.php?t=217145
#62
#63
I have a question. This is a little off topic but O well.
Will the accesories from a 2001 silverado bolt right up to a Z06 motor ?
Also will the fuel rails work off of a 2001 silverado ?
Thanks for any help.
#64
Accessories? Yes.
To run the car intake, you have to re-wire your injector harness to accept the different injectors that the cars use, and also some spacers. Check the FAQ tech sticky in the performance section here in the truck section for a good how-to.
#65
Originally Posted by Scream
Accessories? Yes.
What if i wanted to run the truck intake and fuel rails will it work ?
