Supercharging the Z06
Old Sep 16, 2004 | 10:17 PM
  #51
GMCtrk's Avatar
Originally Posted by BlownChevy
I say you may have taken it in the shorts on that one....I have seen complete LS6 take outs with 1000 miles or less for 2-3gs.
umm, where do you see those??? I'd jump all over that
Old *** ls1's go for like $2000
Old Sep 16, 2004 | 10:40 PM
  #52
BlownChevy's Avatar
blownerator
25 Year Member
www.car-part.com
They are rare but you can catch one every once and a while. There are not any there now, you have to keep your eye open. You can also check e-bay. I may have been off a bit.....maybe in the 3-4000.00 range....
Old Sep 16, 2004 | 11:05 PM
  #53
Z06_Truck's Avatar
Originally Posted by zippy
not sure why you'd need a custom set up for your ati as a standard truck kit with a d1sc should do it. i also agree on the 4L60E, i think a built one can handle what you're looking at putting out. jet certainly isn't where i'd be getting a 4L80E. a pcm from a 97 suburban can be converted to run the LS6, but you're going to be paying out the *** to get it programmed since very few have the ability to program that pcm which is designed around a small mass air system (going to be maxing the maf reading out all the time). it would be considerably easier to use a harness and computer from a 2wd suburban 2500 6 liter model. of course the z06 part caught my attention, i wondered who would post z06 stuff in a truck section.......someone wanting a z06 bad enough to call his truck one.
lol...no actually i have never wanted a sports car...guess trucks are in my blood. I need the custom setup because I am running all Vette accessories. All of the centrifical superchargers on the market are gonna be set up, as far as plumbing to and from the intercooler, for a Corvette and not a truck. I also have to run both the ECM off the Vette and the ECM off the truck in order to get SES light, RPM, oil pressure, etc... to work on the dash. It's a little bit of a project, but nuthin I can't handle with the help of a good friend of mine. Quite a few C/K Chevy trucks have made the switch to either an LS1 or an LS6.
Old Sep 16, 2004 | 11:14 PM
  #54
Z06_Truck's Avatar
Originally Posted by Ling_650vette
Rossler and Extreme Automatics have 4L65E based trans that're handling over 900rwhp, so I wouldnt say the 60/65E trans cant handle power.
And Prochargers have had problems with their head units under high boost from what Ive read but also it was supposedly from P-1SC units and guys were trying to force like way more boost from them then they can handle. But I have heard very good things from the D and F series lines, altho the F may be a little bit more overkill than the D.
And no ifs and or butts, its not an 05 Z06. Why? Because there is no such thing. Not being a dick, just lookin out for a newbie.
What's the difference between a 4L60E and 4L65E? For the time being I plan to run the LS6 for about 5 or 6 thousand miles. Once all the bugs are worked out I will install a Procharger. I should realistically be able to put 500 on the ground. I think before I dwell too much further in power, I really need to invest what's left of my money in the suspension and transmission. I set aside 18k for this project...well actually I put the plans to shave everything on hold. I have about 6k left to get this baby to hook. Now that might the most unrealistic idea of the day...lol. I'm gonna check out those trannies you mentioned. I appreciate it.
Old Sep 16, 2004 | 11:18 PM
  #55
Z06_Truck's Avatar
www.car-part.com
I'm not gonna say that you're wrong, but I have never seen a LS6 with harness and ECM go for under 5000...at least none that I wanted. I have been lookin for this engine for a yr and a half now. I got lucky I found it. Maybe I got screwed, who knows. Guess I'll find out when I get it fired up.
Old Sep 16, 2004 | 11:34 PM
  #56
Z06_Truck's Avatar
Originally Posted by Scream
I've never heard of anyone upgrading and leaving the accessories on the motor. That would add several grand to the swap price (new a/c compressor, alternator, p/s pump, brackets, etc.)
Also, there is no 2005 Z06. The motor, if you have it, would have come from a 2004 vette.
Got any pics of the motor?
I do have pics of the engine. I'm not sure how to post them though. Mind givin me a crash course?
Old Sep 16, 2004 | 11:44 PM
  #57
Flyer's Avatar
WHat are the casting numbers of the heads and the part number on the block, it would be stamped on the block somewhere, an 8 digit number.
Old Sep 16, 2004 | 11:52 PM
  #58
Z06_Truck's Avatar
Well i'm on a job in PA right now and the engine is sitting at home. I don't em off hand.
Old Sep 17, 2004 | 12:23 AM
  #59
couldnt he put on truck 6.0 heads to get a better compression for running the high boost?
Old Sep 17, 2004 | 12:55 PM
  #60
Z06_Truck's Avatar
That's a good question.
