supercharger
Old Dec 15, 2009 | 07:19 PM
onebad-chevy's Avatar
Default supercharger
i was just wondering if the trans in 03 2500hd will hold a supercharger,tune with lt running 33 also 410 gears thanks
Old Dec 15, 2009 | 07:25 PM
sleeperlqx's Avatar
Yes it will. The 4l80e is great, thats what I am planing to swap too for my 33s.
Old Dec 15, 2009 | 07:50 PM
well im glad to hear that what kind of hp would i be looking at for that set up just around about number
Old Dec 15, 2009 | 08:08 PM
TX Tahoe Z71's Avatar
you'll have to post up specs about your truck and what s/c you are looking at. 6.0 or 8.1 engine? Centrifugal, roots, screw-type s/c? How much boost do you want to run?
typically, you will pick up 120-150hp, but that is just a ballpark figure for a properly tuned s/c on an entirely stock setup. Some will be more, some will be less.
Old Dec 16, 2009 | 07:05 PM
it a 6.0 i think ill try 8-9 pounds of boost and what do you mean Centrifugal, roots, screw-type s/c? it will be a magnancharger
Old Dec 16, 2009 | 07:28 PM
supersilverado04's Avatar
There are different type of superchargers. magnacharger is a roots style blower.
Old Dec 16, 2009 | 09:31 PM
a 112 on a 6.0 with 8-9 psi should pick up 150hp properly tuned. There are some top notch tuners on this site who are sponsors; check out Nelson, Blackbear, and Wheatley, links on the right =====>
Old Dec 16, 2009 | 10:35 PM
budhayes3's Avatar
PT's Slowest Truck
The 80E is a strong trans for sure....I'd put a shift kit and big trans cooler on it to complete the package...just my .02
Old Dec 20, 2009 | 03:35 PM
i was just doing some looking around and from what i can find a turbo makes more power at the same boost and cost less sts makes a full kit and i see nelson is comeing out with a front mount kit soon to is a turbo better then a supercharger?
Old Dec 21, 2009 | 08:49 AM
c3tx's Avatar
Turbo kits can make more power at high rpm, but with as big a motors as these trucks have, they dont have terrible turbo lag. They also have more plumbing to set up (ie. up pipe etc). The STS mount the turbo in the back of the truck above the rear axle. I dont have any experience with their kit, but I would think if you off road, or drive in heavy snow it could create problems for you. Could someone who has an STS comment?
moregrip
Jul 26, 2016 11:21 AM
5speedsilverado
Sep 25, 2015 06:50 PM
bagged7104SS
Sep 24, 2015 08:42 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
