supercharger
you'll have to post up specs about your truck and what s/c you are looking at. 6.0 or 8.1 engine? Centrifugal, roots, screw-type s/c? How much boost do you want to run?
typically, you will pick up 120-150hp, but that is just a ballpark figure for a properly tuned s/c on an entirely stock setup. Some will be more, some will be less.
i was just doing some looking around and from what i can find a turbo makes more power at the same boost and cost less sts makes a full kit and i see nelson is comeing out with a front mount kit soon to is a turbo better then a supercharger?
Turbo kits can make more power at high rpm, but with as big a motors as these trucks have, they dont have terrible turbo lag. They also have more plumbing to set up (ie. up pipe etc). The STS mount the turbo in the back of the truck above the rear axle. I dont have any experience with their kit, but I would think if you off road, or drive in heavy snow it could create problems for you. Could someone who has an STS comment?
