Super Victor pics
Old Jun 26, 2008 | 12:50 AM
LIL SS's Avatar
Default Super Victor pics
Thought I would share as there are not too many of these intakes around yet. This is not a Vic JR, but rather it's mean big brother the Super Victor. It's topped with a NX Shark SX2 Nozzle plate system. On top of that there is a dominator to 4150 adapter. Then there will be a dominator throttle body that is good for 2k cfm.
I have no idea of how this set up is going to work. Could be a waste of time, but we'll see..
It needs a little touch up port work that I will do. Now I'm wondering if I want to top it with a velocity stack or a hilborn scoop that sticks out of the hood on the 63 pickup..
Old Jun 26, 2008 | 02:57 AM
chevyguy7802's Avatar
Awesome! Can't wait to see the results! Motor looks good too!
Old Jun 26, 2008 | 11:22 AM
budhayes3's Avatar
PT's Slowest Truck
That rocks!! If I was building a street rod or old skool truck, that would be my setup!
Old Jun 26, 2008 | 12:13 PM
Big Red Truck's Avatar
11 Second Truck Club
That is Drop Dead Sexy!
Old Jun 26, 2008 | 12:21 PM
Wilde Racing's Avatar
How do I change this text
that thing look HUGE!!
on a side note, is there enough belt wrap around that water pump???
Old Jun 26, 2008 | 12:48 PM
LIL SS's Avatar
Thanks Guys..
Wilde, not sure I follow.. Are you asking if there is enough belt to spin the pump? If so, works great for me..
Old Jun 26, 2008 | 02:21 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by LIL SS
Thanks Guys..
I agree with Wilde, that wrap around the water pump and crank pulley might cause you issues later.
Old Jun 26, 2008 | 02:33 PM
LIL SS's Avatar
Mind advising what issues?
I have aprox 1000-1500 miles on the motor with the belt set up that way with no ill effects so far. The belt is extreamly tight getting on, meaning there is quite a bit of tension on it. But if you have had problems in the past with such a routing, I'm all ears..
Old Jun 26, 2008 | 02:44 PM
It just doesn't look like a lot of contact between the belt and the pullys. I'm sure you know that having a belt too tight will cause more problems with bearing failure;
Old Jun 26, 2008 | 02:46 PM
BlownChevy's Avatar
blownerator
25 Year Member
looking at the crank and water pump I would estimate your belt contact area to be approx 20%, under high RPM load this will not be enough to keep the water pump and crank from spinning faster than your belt. (belt slip) If you have it as tight as I think you do, eventually you will wear the front main bearings, Alt bearing, and water pump bearings.
I would suggest two idlers and bringing the belt wrap around the crank and water pump.
