Stroker Piston Question
Old Feb 24, 2008 | 12:55 AM
shakinlm7's Avatar
Default Stroker Piston Question
If a piston is listed for a 4.125 stroke I should be able to use it on any stroke UP to that right?
Also could someone verify my calculations? I think its right but this was the first time I've ever done it....
4.0 stroke
6.125 rod
3.903 bore
1.06 Compression Height
11cc reverse dome pistons
66.67 cc heads
.040 Head Gaskets
I came up with a 382.85 CI stroker with 8.14:1 Compression
Old Feb 24, 2008 | 12:56 AM
shakinlm7's Avatar
This is the piston I want to use btw,
Old Feb 24, 2008 | 11:10 AM
shakinlm7's Avatar
Back to the top
Old Feb 24, 2008 | 02:17 PM
Dark Halo's Avatar
4.0 stroke
6.125 rod
3.903 bore
66.67 cc heads
.040 Head Gaskets
I know alot of the stroke the piston is designed is due to the side skirts and how the piston is made and rod length. Maybe someone with a litle more experince will chime in
ferrellrooster
Mar 6, 2025 03:22 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
lycominghunter
Aug 15, 2015 12:26 PM
chevysten
Aug 13, 2015 07:36 PM
USMCvet0311
Aug 1, 2015 07:45 AM
