Stroker Piston Question
If a piston is listed for a 4.125 stroke I should be able to use it on any stroke UP to that right?
Also could someone verify my calculations? I think its right but this was the first time I've ever done it....
4.0 stroke
6.125 rod
3.903 bore
1.06 Compression Height
11cc reverse dome pistons
66.67 cc heads
.040 Head Gaskets
I came up with a 382.85 CI stroker with 8.14:1 Compression
4.0 stroke
6.125 rod
3.903 bore
66.67 cc heads
.040 Head Gaskets
4.0 stroke
6.125 rod
3.903 bore
66.67 cc heads
.040 Head Gaskets
4.0 stroke
6.125 rod
3.903 bore
66.67 cc heads
.040 Head Gaskets
5.3lSilverado
25
Aug 29, 2016 12:48 AM
lycominghunter
Aug 15, 2015 12:26 PM
