Stroker ?
Old Oct 20, 2002 | 03:22 PM
try'in2bfast's Avatar
Default Stroker ?
Has anyone heard of a stroker kit for the 5.3?
Old Oct 20, 2002 | 03:51 PM
Jason 98 TA's Avatar
FormerVendor
Default Re: Stroker ?
You could build a 382 out of a 5.3L truck or a 4.8L truck!
Old Oct 21, 2002 | 06:29 AM
Where can i get some info on it.I'm wondering how much it costs and the power gains from it.Thank you for the reply.
Old Oct 21, 2002 | 08:04 AM
BigTex's Avatar
I doubt that you'll find any true stroker "kits" for the 5.3 engine. But, there are a few manufacturers who make stroker cranks and rods for the LS1 based engines. Those will fit the 5.3 block. Then the issue is getting correct pistons. Prices for the crank itself are several thousand. Then you run into the problem of the 5.3s heads not flowing well enough to support that power. Cant tell you any ET gains, but more cubes would definitely up the torque. With a 4" stroke, you would net about 360 ci.
A better budget solution would be buying a 01+ 6 liter longblock thats already 364 ci. Have it bored .060 over, and get the crank offset ground for a little longer stroke, then add forged pistons. This would give you 383 ci. This option isn't all that cheap, but its cheaper than a Lunati crank.
Old Oct 21, 2002 | 08:12 AM
GREGGO's Avatar
Rumor is that there is a 4" stoke that may be coming our way via Australia that's rated for 600hp or 800hp (don't remember which) applications for about $800. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I'll post when I can get more info.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
sTNT971
Sep 26, 2015 04:22 PM
MOBBN
Sep 22, 2015 08:07 PM
