from stock rear end to ??????
Old Mar 17, 2003 | 12:17 AM
hamburgler25's Avatar
Default from stock rear end to ??????
hey guys,,im realativly new,,i have an 00 scsb truck with regular mods (hpp lll,stat,wires,air intake,spacer,etc),,now i need traction. i have 3.73 but need to get an eaton posi,,but what more can i do to increase the strentgh of our rear ends,,is there a rear end girdle,,axles,,and who makes them,,or what is your suggestions. i work less than a mile from currie enterprises in anaheim california,,but they want 2500 bucks for a 3.92 geared nine inch with disc breaks. would be nice,,but man thats alot of doe. i can get an eaton installed for right round 485.00 installed but what other suggestions do you guys think,,thanks for your help,,
also,,,gettin some caltracs as well,,,
Old Mar 17, 2003 | 01:27 AM
1999stepside's Avatar
Default Re: from stock rear end to ??????
Unless you plan on some serious power...the 8.6" rear with the eaton and a differential cover should hold up fine. F-body's have 7.5" rears, so that is why you see them breaking them quite often.
kent
Old Mar 17, 2003 | 04:29 PM
thanks kent,,the only other mods i will get will be about a 100 shot of funny gas,,a 2400 yank,,and trans stuff,,then a program like edit, to tune it all in,,,when i get to 13.5 et's,,ill be happy with the performance,,then i will paint it, etc,,,went to fontana raceway here in southern cali,,and ran back to back 14.97 runs,,,no stalling,,brake to gas pedal,,as if i stall it at all,,i burn the 255,55 16s up in smoke,,or should i say,,,single 16,,,any ideas where to get the cover ?? thanks again for everyones help
thunder550
Oct 8, 2015 04:53 PM
pjb1972
Sep 17, 2015 02:06 PM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ketis
Jul 23, 2015 12:37 PM
