Stock Plug Gap .035
Old Aug 13, 2005 | 10:38 AM
03sierraslt's Avatar
Default Stock Plug Gap .035
I just started pulling my plugs to change them and my stock plugs are gapped to .035? I thought they were suppose to be .060? Is there any point in my putting in TR55's? The plugs that are in it are ACDelco 12571164 Iridium's Gaped at .035 I have never touched the plugs before.
Old Aug 13, 2005 | 11:17 AM
one03sierra's Avatar
Formerly one92rs
Talking
unless you are having missfire issues i would leave the iridiums in there.
Old Aug 13, 2005 | 11:19 AM
That is my thought too, but I would like to go one heat range cooler before I go any higher with my boost. I guess that would be TR-6's ( NGK )
Old Aug 13, 2005 | 03:05 PM
KLUG'S SS's Avatar
FormerVendor
Had the same thing with my truck, when I pulled out my stock delco plugs I checked the gap on them and they were .035 also. I thought that was kind of strange considering the factory sticker under the hood says .060.
Old Aug 13, 2005 | 03:32 PM
budhayes3's Avatar
PT's Slowest Truck
I thought that the factory gap for the iridium plugs was .045, and .060 for the platinums, and the iridium plugs are supposed to be pre-gapped when you buy replacements. FWIW, my truck (99 5.3) came with AC Delco platinums, and when I pulled them out a few years ago to check them, the gaps varied from .045 to .065. They all looked good and the truck ran fine, just had inconsistent gaps.
Old Aug 14, 2005 | 03:53 PM
Well I am going to throw in some TR-6's at .035
Old Aug 15, 2005 | 10:11 AM
Mort's Avatar
Cool
That is what I am using and no problems so far that I know of. I am slowly bringing the boost back up and I am up to about 8 psi so far. Still not quite as high as I was getting when I had the red wastegate spring. Time to give the boost control another turn.
Old Aug 15, 2005 | 10:28 AM
leochevy2001's Avatar
i had double platinums in my stock and changed them out to the tr55s. i think i might go back to what the factory plugs were.
Old Aug 15, 2005 | 10:33 AM
If it wasnt for the supercharger then I would just leave the factory plugs in.
The_W
Oct 28, 2015 09:00 PM
JordanH
Aug 8, 2015 07:59 PM
Gadgetized
Jul 18, 2015 02:15 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
4B11T
Jul 13, 2015 03:48 PM
