Sticky tires?
Old Jul 8, 2005 | 07:44 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Sticky tires?
Ok well here is my problem I recently installed my nitrous kit and my truck flat out hauls out of the hole. Well with the stall and nitrous all four tires spin a little out of the hole quite often. In about two months Im going to be installing h/c 6L in my truck that will make as much power as my truck now on the nitrous and I will be spraying a 175 shot on top of that and get my stal bumped from 3000 up to 3600-3700 so there will approx. 150-200 more hp on tap off the line . I know Im going to have traction problems on the street in 4wd so Im going to atleast need some stickier tires. I need some stickies that are stock hieght not lo pros cause that would look retarded on my Z. So what kind of street tires has everyone had good luck with so I dont waste a bunch of money?
Old Jul 8, 2005 | 12:38 PM
TURBHOE's Avatar
305/60 R17 119V or 305/55 R18 117V depends on what size rim you have but they have to be between 8.5-(9.0)-11.0 wide. the second is the one i want when i get my 18's
Old Jul 8, 2005 | 01:13 PM
1slow01Z71's Avatar
Rollin on stock 16s no $ for rims Im more of an all go and no show. I have a billet grill tailights and clear corners and billet z71 third brake light cover and thats it. Need some that are going to be real close to stock height too.
Old Jul 8, 2005 | 01:46 PM
TURBHOE's Avatar
those two i put on are just a hair short of the z71 stock tires. but i dunno about stock 16's
Old Jul 8, 2005 | 02:23 PM
1slow01Z71's Avatar
What brand are they?
Old Jul 8, 2005 | 02:49 PM
TURBHOE's Avatar
my bad nitto 404's
Old Jul 8, 2005 | 03:17 PM
TXsilverado's Avatar
z71's came with 2 different sized tires from the factory. 245/75-16@30.5" tall and 265/75/16 @ 31.5" tall. which size are you looking for?
Old Jul 8, 2005 | 03:22 PM
check out the toyo proxy 275/70-16. its at 31.1" tall (right in the middle of the 2 factory sizes) and i hear great things about toyos hooking up and getting good milage. they're what im going for when i burn mine off.
Old Jul 8, 2005 | 03:24 PM
1slow01Z71's Avatar
Well tx if I convert you to the darkside(nitrous) I promise you will need them sooner rather than later. Ill have to look in to the proxys.
Old Jul 9, 2005 | 07:23 AM
1slow01Z71's Avatar
need more opinions
