steering popping?
Old Mar 4, 2004 | 02:56 PM
O3GMC's Avatar
12 Second Club
Default steering popping?
At low speeds while turning I feel/hear a slight popping/thudding in the steering...it just started doing this a few months ago and I've had the drop on for alot longer then that. Could it be related to the 2" drop in the front?
Old Mar 4, 2004 | 03:10 PM
1BADHD's Avatar
You need to repack your steeting shaft. There is a TSB on it. Check it out.
Old Mar 4, 2004 | 03:15 PM
Z71/99's Avatar
I have the smae problem and would really like to know how to fix it also, sao if anyone has any info please inlighten us.
Thanks
Cory
Old Mar 4, 2004 | 03:21 PM
Z71/99's Avatar
Thanks
Cory
Old Mar 4, 2004 | 03:26 PM
FLATOP08's Avatar
HERE YOU GO Document ID# 1394286
2003 Chevrolet Chevy C Silverado - 2WD
Clunking Noise Under Hood and Can Be Felt in the Steering Wheel (Lubricate Intermediate Steering Shaft Assembly) #00-02-35-003C - (10/20/2003)
Clunking Noise Under Hood and can be felt in the Steering Wheel (Lubricate Intermediate Steering Shaft Assembly)
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon XL
2003-2004 HUMMER H2
With Recirculating Ball-Type Steering
This bulletin is being revised to add additional procedures and time for vehicles equipped with adjustable foot pedals and to add additional models and years. Please discard Corporate Bulletin Number 00-02-35-003B (Section 02 -- Steering).
Condition
Some customers may comment on a clunk-type noise coming from under the hood that also can be felt in the steering wheel. These conditions may be more noticeable when turning at low speeds on rough road surfaces.
Correction
Important
DO NOT REPLACE THE FOLLOWING INTERMEDIATE STEERING SHAFT P/Ns:
26085548
26049343
26083324
26088325
15772436
26078079
Remove the intermediate shaft from the vehicle and lubricate the intermediate shaft with a Steering Column Intermediate Shaft Lubrication Kit, P/N 26098419. Follow the service procedure below.
Set the front wheels in the straight-ahead position.
Set the steering wheel in the LOCK position.
Install the J 42640 in the steering column lower access hole.
For vehicles equipped with adjustable foot pedals, do the following steps.
Reposition the carpet away from the accelerator pedal position (APP) sensor.
Remove the two nuts retaining the accelerator pedal to the bulkhead.
Reposition the accelerator pedal out of the way so that the intermediate shaft can be removed.
From inside the vehicle, remove the upper bolt from the upper intermediate steering shaft (1) to the steering column connection.
From under the hood, remove the lower bolt that connects the upper intermediate shaft to the steering gear coupling shaft.
Remove the upper intermediate steering shaft assembly.
From inside the vehicle, slide the shaft down and off the steering column shaft.
From under the hood, slide the shaft towards the dash in order to disengage the shaft from the steering gear coupling shaft.
From inside the vehicle, slide the upper intermediate shaft through the dash boot seal and remove the shaft from the vehicle.
Remove the spacer clip from the end of the intermediate shaft with a pair of needle nose pliers.
Fully extend the shaft by pulling the two shafts apart.
Apply the syringe of grease supplied in the Steering Column Intermediate Shaft Lubrication Kit, P/N 26098419, into the open end of the shaft. Direct the syringe tip as deep as possible into the shaft and dispense the full content of the syringe.
Insert the plug supplied in the Steering Column Intermediate Shaft Lubrication Kit into the open end of the shaft and finger tighten the wing nut.
Place the plugged end of the shaft on a hard surface and apply pressure to collapse the shaft and dissipate the grease through the shaft.
Remove the plug from the shaft and fully extend the shaft.
Inspect the shaft for a minimum of 13 mm (1/2 in) of grease on the shaft splines.
Repeat steps 11-14 if less than 13 mm (1/2 in) of grease is on shaft splines.
Clean the excess grease off of the shaft splines and around the shaft opening.
Carefully spread apart the spacer clip with a pair of pliers.
Reinstall the spacer clip into the open end of the shaft.
Align the spacer clip with the stakes in the shaft.
Reinstall the upper intermediate steering shaft through the dash boot seal and slide the lower end into the steering gear coupling shaft.
Raise the upper end of the intermediate steering shaft and install into the steering column shaft.
Install the upper bolt and nut. Tighten
Tighten the bolt to 47 N·m(35 lb ft).
Install the lower bolt and nut. Tighten
Tighten the bolt to 50 N·m(37 lb ft).
Reposition the accelerator pedals into position on the bulkhead.
Install the two retaining nuts. Tighten
Tighten the nuts to 20 N·m (15 lb ft).
Reposition the carpet back into place.
Parts Information
Part Number
Description
Qty
26098419
Lubrication Kit, Steering Column Intermediate Shaft
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E7700
Shaft, Steering Intermediate - R&R (Lubrication)
0.4 hr
Add:
0.2 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Old Mar 4, 2004 | 03:46 PM
1BADHD's Avatar
That is what I just said to do........in many many less words! LOL
Old Mar 4, 2004 | 03:48 PM
FLATOP08's Avatar
Hey 1BADHD I work at a dealer and its easy to copy and paste LOL
Old Mar 4, 2004 | 03:52 PM
1BADHD's Avatar
Its all good.
Old Mar 4, 2004 | 05:36 PM
hey I had the same prob when I did headers they sent the wrong ones as the
years of the truck get newer the steering shaft gets closer to the manifold
so if you have headers especialy edlebrok I would look into that there is a bolt right there that you can trim to fit better
Old Mar 4, 2004 | 06:25 PM
Deckhand's Avatar
had the same, problem, took it in, got it fixed, good luck!
