starting is rough, then hesitates.
Old Jun 6, 2007 | 08:48 AM
2k4tahoe's Avatar
Default starting is rough, then hesitates.
on my 99 silverado its starting to take more to get it started like in the mornings. then it will hesitate some till i get going then its fine?
any common things i should look into?
Old Jun 6, 2007 | 12:49 PM
silent1's Avatar
What kind of mileage and maintenance does your truck have? are you getting an SES light? It could be quite a few things: Leaky or torn fuel pressure regulator, weak fuel pump, worn spark plugs, clogged fuel filter, clogged injectors, etc.
Old Jun 6, 2007 | 12:55 PM
jconner111's Avatar
Pull The Vac Line Off The Fp Regulator And Start It...if Fuel Comes Out..needs A Regulator
Old Jun 6, 2007 | 01:15 PM
2k4tahoe's Avatar
seafoamed it a month ago, 156K miles, its had a tune up within 10K miles. i was thinking some kind of vaccuum leak.
Old Jun 13, 2007 | 04:09 PM
2k4tahoe's Avatar
stupidity moment, where exactly is the fuel pressure regulator? im sure i could find it, but having more knowledge than needed always helps.
Old Jun 13, 2007 | 05:46 PM
gmforlife's Avatar
Another easy check is the Throttle Body. With that much mileage your TB could be gummed up pretty bad. I had a buddy that i was helping tune his truck and the frickin truck would idle at 300 rpm and if you crank the wheels it would stall, he had 70K on his truck. this might not be your problem, but it's an easy check, start with the easiest. Fuel filter would probably be next or something like that.
Old Jun 13, 2007 | 08:35 PM
budhayes3's Avatar
PT's Slowest Truck
It's located in the middle of the driver's side fuel rail...it's round with a vacuum line going to it. Pull the hose off of it and check for the presence of fuel or a strong fuel smell...if you have either, the fp reg is shot and needs to be replaced.
Old Jun 13, 2007 | 09:47 PM
SBChvy's Avatar
If its not the fuel pressure regulator then I would look into a 2002 computer. My 2000 did the same thing, and it even would do it at slow speeds-like in a parking lot-ending up swaping the computer to a 2002 and it solved the issue.
Old Jun 14, 2007 | 08:12 AM
2k4tahoe's Avatar
cool guys i will check it today, i already cleaned the TB that was the first thing when me and my girl got together, i let her take my tahoe and i drove her truck and the gas pedal stuck and man that was shitty.
i think i got a grip on what to do now, thanks guys.
Old Jun 14, 2007 | 09:23 AM
duwem's Avatar
I am on the same boat kinda. The last 3 days when I start the truck when cold it revs up to 1500 then drops down to 500 and hesitates bad, I am thinking the idle bypass is skrewed up????? Would it be going bad? I had it out and cleaned less than a year ago.
One I get above idle rpm it cleans up.
