Starting Issue
Old Jul 29, 2008 | 04:24 PM
Default Starting Issue
Hey guys I have a problem with a 97 chevy pickup starting up. When I go to crank it it will not crank. I have checked fuel pressure and it is above 40 psi, the only way that I can get it to crank is by removing the air filter and spraying Carb cleaner down the air intake. After I turn it off it will not crank up again, what could be wrong?
Old Jul 29, 2008 | 11:02 PM
Superado's Avatar
11 Second Truck Club
return type system?
maybe pump not priming the fuel line...
in-tank pump, correct?
check valve in pump malfunctioning?
try turning the key on for 2-3 sec's...then off...then back on for 2-3 sec's again...then try to crank...
zblee
63
Jun 10, 2023 01:25 PM
treylittlefield
Jan 24, 2016 07:38 PM
97aztecgt
Aug 13, 2015 02:11 PM
05GMC4.8
Aug 7, 2015 09:55 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
