Stall & Tune
Old Oct 15, 2004 | 07:16 AM
Silver-Dollar's Avatar
Default Stall & Tune
How high of a stall can be used without a tune? What causes it to need to be tuned?
Old Oct 15, 2004 | 07:56 AM
FILE's Avatar
I'd imagine if you go with a very high stall you comp might start throwing codes believing your tranny is slipping.
Old Oct 15, 2004 | 08:20 AM
When I put in my high 2800 stall and shift kit, I really started feeling the effects of torque management. It really sucked out all the power for 2-3 seconds after each shift. That was my original reason for getting ls1 edit a while back.
Old Oct 15, 2004 | 08:55 AM
2 to 3 seconds? Seems like that would defeat the purpose of a TC. I was considering a comparable stall speed. It almost seems I need to suck it up and either get the ls1edit or a paid service.
Old Oct 15, 2004 | 10:32 AM
Yep, that's what i thought too. I really hadn't noticed torque management until after these mods. After removing TM though, it shifts fine with no power loss.
I don't think i had a problem with the converter locking/unlocking after the stall until I changed my cam. But this was also fixed with ls1 edit.
Old Oct 15, 2004 | 12:03 PM
Thanks for the info. I see by your sig that you have the software. How much automtive experience did you have prior to doing your own edits did you have before you puirchased it?
Old Oct 15, 2004 | 12:32 PM
Absolutely none. I've mainly just used it so far to turn off codes, change the upshift and downshift points, adjust the tire size, delet TM, and tweak the timing. I haven't gotten into the complicated stuff such as fuel trims.
LCHEE
Oct 24, 2020 04:10 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
noproblems209
Aug 10, 2015 06:57 PM
Dirtywhite
Aug 5, 2015 04:10 PM
Castro45
24
Jul 31, 2015 07:13 PM
