stabilitrak is gonna kill me
Old Apr 22, 2004 | 02:10 PM
grooves12's Avatar
In my manual... it is in the section that starts on page 4-9
Old Apr 22, 2004 | 02:16 PM
01Blackerado's Avatar
And if all else fails you can always make your own toggle switch but it needs to be the kind with three electrode posts on the bottom GND/ ACC./ POS. And if you don't want to do it that way then you call always just look for the fuse it runs off of in one of your boxes and see if that takes care of it.
Old Apr 22, 2004 | 06:08 PM
LOW2000's Avatar
The instructions i posted were from the 2000 factory service manual. Quite possible the procedure changed for 03-04.
Old Apr 22, 2004 | 08:40 PM
Mr. Sandog's Avatar
I just tried this today and was successful. I followed the directions included in the other post, but there was an addition from my manual:
1) Turn car two clicks to 'On' (dont' stop at 'Accessory'); don't start car
2) Press foot on brake
3) Shift to 'N' Neutral
4) While holding the brake down, put accelerator to the floor
5) Hold 'TC' switch in for at least 6 seconds
6) Let off on TC switch, brake, and accelerator
7) Turn key off
8) Wait a while, then when you start the car again, TC will be off
Follow procedure again to reset to original setting.
Old Apr 23, 2004 | 03:22 AM
Flyer's Avatar
I wonder who thinks these things up ....
Old Apr 23, 2004 | 09:33 AM
Boosted 6.0's Avatar
short of claping my hands and blinking twice, the above worked. The stabilitrak didn't turn off until I drove about a mile. Weird. Also, there is no instructions in my manual. Oh well, thanks for the info.
Old Apr 23, 2004 | 11:05 AM
grooves12's Avatar
Good job, I still don't beleive you were looking hard enough though...
Try pages 4-9 through 4-11
Old Apr 23, 2004 | 11:16 AM
Mr. Sandog's Avatar
Glad you got it working...
Old Apr 23, 2004 | 01:47 PM
LOW2000's Avatar
In the factory service manuals, I found it under the brakes section. Perhaps with the advent of the throttle by wire, it may not be controlled by the brakring system like it used to, but it should still be recieving its info from the abs sensors.
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
Wolftrk99
Oct 2, 2015 08:17 AM
twake_410
Sep 25, 2015 10:09 PM
