stabilitrak is gonna kill me
Old Apr 21, 2004 | 10:34 PM
Boosted 6.0's Avatar
Default stabilitrak is gonna kill me
Stabilitrak / traction control is gonna kill me or somebody who barrows my truck. I hammer it, the truck surges and than stalls (usually when I'm merging in traffic) because the wheels start spinning. I have a habit to turn it off when I start it up, but anyone barrowing my truck won't know and that could be fatal. Anyone know how to reverse the system so it's always off unless I push the button?
Old Apr 21, 2004 | 11:08 PM
NovaTime's Avatar
well, if you turn it off by the push of a button, reverse the circuit (switch power and ground)...that should essentially make it function the other way. when you put a DC motor to 0, it spins backwards and when you put it to high it will spin forwards.
Old Apr 21, 2004 | 11:12 PM
I hope it's that easy, does anyone know if this will screw up any of the pcm programming? Does anyone else have this problem?
Old Apr 21, 2004 | 11:18 PM
NovaTime's Avatar
it shouldn't. The PCM will still get a signal, you are just changing what sets the traction control to high and what sets it to low.
Old Apr 21, 2004 | 11:30 PM
will I need to pull apart the dash and do this or can i pop the bezel surrounding the button??
Old Apr 22, 2004 | 01:38 AM
Flyer's Avatar
That won't do anything. If it's like most other switched in the truck, it's a momentary switch, which means the circuit is closed as long as you push the button down. That's what switches the PCM mode, a momentary closed circuit.
There was a post a while back on how to set it so it defaults to the off position, but I forget how to do it. You might try some searches.
Old Apr 22, 2004 | 02:53 AM
LOW2000's Avatar
Do a search on my user name, I posted directions on how to do it last week I believe.
Old Apr 22, 2004 | 01:19 PM
I followed those directions, it didn't work. I also checked my manual and there is not instructions on changing the default to off. Do you think it's changed for 03's??
Old Apr 22, 2004 | 01:29 PM
Flyer's Avatar
You might can call the dealership and ask them how to do it. They should be able to tell you over the phone.
Old Apr 22, 2004 | 01:41 PM
grooves12's Avatar
I have an 03 and it IS in the manual. I followed the instructions, and it worked perfectly. The only thing that is sort of annoying is that the indicator light is now ON all the time, but I got used to it.
I still turn it on when it is wet out, as I found it does a good job when surface conditions are poor, but like you I felt on dry ground the way it operates was EXTREMELY unsafe. Whenever I would pull out of a driveway or make a right hand turn onto a busy road, the rear would spin up, and it would KILL all power and buck like a Bronco leaving me dead in the water with oncoming traffic barrelling down on me.
Look in your manual again... I am SURE it is in there.
