Spun bearing after procharger install
#22
Not blaming anyone, things happen with mods I understand that completely...
Just wanna know what's wrong and why so it doesn't happen again when I rebuild it. If it was just the tune that's fine I can live with that I had an appointment for a dyno tune and yes I probably should of just waited to drive it until after that I use see a lot of people using the bb tune and it working fine. I do lap percolate all the input. I'm pulling the head next week so I will see then how much I gotta do to fix it.
#23
#24
Pulled both heads tonight, Cylinder 6 piston is wobbly and was hitting head lightly. Guesing the rod is bent but going to pull the pan tomorrow. I am thinking best option is just getting all new rods and pistons. How bad is the install whithout pulling the engine? Ill go ahead and stud them as well as ls9 gaskets and new injectors while I'm at it
#26
Whatever you do as for fixing motor make sure you get yourself a good tune from a tuner who is used to dealing with a lot of power.
Cause a stout motor can fail in the hands of a non experience tuner
#27
Andrew at complete street performance in west Chester pa is who I was going to use. He tuned my camaro and I've watched him tune a lot of much higher HP cars while at his shop
ARC
57
Feb 21, 2022 10:54 AM
Dezert1500
Jul 30, 2015 02:51 PM
