Speed Engineering True Dual Exhaust Prototype..
Old Jul 24, 2018 | 09:17 AM
  #881
Speed Engineering's Avatar
Former Vendor
RedXray: Thank you for your comments. Our revised version which came out a few months ago does not use the hanger on the muffler any more. The hanger is now adjustable and positioned on the exhaust tubing. Our clamps have also been re-engineered after two years of requesting a better clamp design with the factory. They perform very similar to an Accuseal clamp now.
Thanks
Sean
Old Jul 25, 2018 | 02:44 PM
  #882
RedXray's Avatar
100% Redneck
Thanks
Sean
Sean do you have a pic of the adjustable hanger and can it be purchased individually?
Old Jul 26, 2018 | 09:28 AM
  #883
Former Vendor
We don't offer it individually sorry. The change was made while adapting our kit to the 2014+ trucks, and is now included to compensate for the different hanger locations. It might even work with the SUV's now not sure.
Thanks
Sean
Old Sep 18, 2018 | 01:18 PM
  #884
hunterbohanan23's Avatar
Another review here.. Had my exhaust for roughly over 2 years now. No fitment issues what so ever. Clamps seem to be everyone's biggest issues. When I first installed this exhaust I made the mistake of putting the bolts right where the slits are for the pipes to connect, which caused leaks. Since having to take the entire exhaust off (removed transmission for stall converter) we reinstalled the clamps but turned them where the solid piece of the clamp was over the slits. And tightened the bolts with air gun to ensure the tightest possible. Since then the exhaust has actually been "throatier" and sounding much better at all RPM's. Sounds awesome and still looks good after 2 years. We did have issues with the hanger by the mufflers but decided to not use it since the exhaust was already very sturdy. Can't wait to throw a cam in it on a 108 LSA and hear how good it'll idle. The only thing I wish I could do is run the exhaust to the RST tips on my roll pan. But that isn't on Speed Engineerings part at all. Truck is a 06 RCSB.
Old Sep 24, 2018 | 08:03 AM
  #885
Former Vendor
Thank you for the comments/business..
Sean
Old Sep 25, 2018 | 11:49 PM
  #886
L33z71's Avatar
I have a question about the x,pipe. With some modification cutting and welding, do you think I will be able to make the xpipe work with the stock y pipe? Im ordering your guys' shorties but I want to do true dual with your xpipe, but since its only for use with the long tubes, do you think that I would be able to fit the xpipe with the oem ypipe by cutting the xpipe to match as closely more or less to be able to weld together?
im eger to try but you guys know the fitting more so I want to know if its worth a try?
THANKS!
Old Sep 26, 2018 | 08:37 AM
  #887
kaze_v8's Avatar
THANKS!
What on earth?
Old Sep 29, 2018 | 02:13 PM
  #888
dhpro's Avatar
@speedengineering: can I assume 99-06 axle dump Sierra system will fit my 04 Avalanche? I have an SE 4L80E conversion as well and long tubes.
Thanks
Old Oct 1, 2018 | 09:58 AM
  #889
Former Vendor
Our axle dump kit will fit within the chassis of an Avalanche, but I believe the hanger points are in different locations than the trucks. Yes, it will work with a 4L80E trans.
Thanks
Sean
Old Dec 11, 2018 | 12:48 AM
  #890
wildmanaaron's Avatar
Are you making any of these kits now for the Tahoe/Yukon?
