Speed Engineering True Dual Exhaust Prototype..
Old Mar 13, 2016 | 11:40 AM
  #431
stryduh's Avatar
I added extension pieces at both collectors and then between the x-pipe and the rear pipes. The back of the x-pipe is just touching the trans crossmember. I think a little bending of the rear exhaust hanger will solve that though. I have not driven it too much yet to notice any drone. The mufflers do take on a different tone after warming up for a few minutes.
Old Mar 14, 2016 | 01:28 PM
  #432
Speed Engineering's Avatar
Former Vendor
25hdtankhauler: We haven't had any issues with 4L60E installs. The larger transmissions are the only ones. The 6 speed auto just needs to have the 90* tube extended 1", which we have already sent that to the factory. I am hoping that should be adjusted before our next batch comes in. Will see. And (stryduh) is the only one that I am aware of that has tried our system with a 4L80E.
Thanks
Sean
Old Mar 14, 2016 | 02:01 PM
  #433
Ken in AZ's Avatar
I installed the prototype system on my silverado that has a 4L80e swap. It fits a little snug to the trans pan but some exhaust wrap should solve any concerns there.
Old Mar 14, 2016 | 06:55 PM
  #434
Chevy305's Avatar
Any chance you would make a non polished version? Could that save some money? I'm thinking that I daily drive my truck and that a polished finish certainly isn't necessary.
When do you think the batch to clear the 6l80s will be ready?
Old Mar 15, 2016 | 09:52 AM
  #435
09CamdSilvy's Avatar
I have a RCSB and MD requires the exhaust to go past the rear axle assy. If i purchased the extended cab version would the length be about right to clear the rear axle? Or just trim it to fit? Thanks
Old Mar 15, 2016 | 11:07 AM
  #436
Former Vendor
Ken in AZ: Thanks for the heads up.
Chevy305: We dont plan on offering them in non polished sorry. The new 90* tube "hopefully" will be in our next batch, which is probably 3-4 months out.
09CamdSilvy: I dont believe it would extend it to the rear end no. Its only about 18" longer.
Thanks
Sean
Old Mar 15, 2016 | 11:53 AM
  #437
Any plans in the works for a kit that extends over the rear axle then dumps? Also, since the y-pipe is not catted i'm assuming the rear o2's would have to be disabled on our lovely computer trucks?
Old Mar 16, 2016 | 02:03 PM
  #438
Former Vendor
Yes, we do plan on offering an over the axle version. I wouldn't expect to have that available for another 10-12 months however.
Yes, the rear O2 sensors will not be needed, and will require them to be tuned out.
Thanks
Sean
Old Mar 17, 2016 | 06:55 PM
  #439
25hdtankhauler's Avatar
Registered User
Sean, for us that are ready now for LT's and just don't need stainless, how do the collectors match up to stock exhaust. I want a set that I don't have to buy a set of flex pipes are to much mod in cutting of exhaust pipe flanges to make collector connection. If I hadn't just repiped my truck I would defently go for your dual system..... Dude they are awesome .... 03 25HD 6.0 crew LB rebuild for cross country RV cruising.
Old Mar 17, 2016 | 08:18 PM
  #440
Registered User
And I read the 20 page discussion on sponsors cornor about the LT's and ++++++ fitments and didn't see answer to my question.
