Speed Engineering True Dual Exhaust Prototype..
Old Mar 2, 2016 | 11:12 PM
  #391
Sexyrado327's Avatar
did i miss the info. Is there a wideband bung in them, heard that the one in the middle might hit the pan will it be changed over to the middle of the X??
Old Mar 3, 2016 | 07:34 AM
  #392
bisqikss's Avatar
yes, the o2 bung in the middle is angled up a little to far. could not get my wideband in. gonna have to cut out and weld in at different angle. still looks great though and fits great! just the o2 bung like the headers on driver side and the clamps.
Old Mar 3, 2016 | 10:04 AM
  #393
Speed Engineering's Avatar
Former Vendor
Ya, the clamps will work even with the wedge. They are just a pain to get on. We have already informed the factory to add some length to the straps. Those should be updated on future batches. The wideband O2 bung was also welded up a little to far. Not sure why they did that. The prototype was welded just fine. They have been informed about that as well. Everything else we have checked/tested should be good to go. We have installed 3 of them on different vehicles so far, plus the ones going out to you guys successfully. If we come across anything else we will continue to perfect our kit. Thanks for the input..
Sean
Old Mar 3, 2016 | 10:20 AM
  #394
bisqikss's Avatar
sean, you guys are awesome. not many companies respond to the feedback from there customers like you all do.
Old Mar 3, 2016 | 12:10 PM
  #395
Wolftrk99's Avatar
Sean, what the dimensions of the mufflers with the kit??? Mostly the length....
Old Mar 3, 2016 | 08:32 PM
  #396
parks450's Avatar
So do we need oxygen harness extension for these? Just curious so I know ahead of time. I assume so
Old Mar 3, 2016 | 08:40 PM
  #397
bisqikss's Avatar
no o2 sensor extensions needed. they plug in just fine
Old Mar 3, 2016 | 11:45 PM
  #398
parks450's Avatar
Are you guys tuning with just exhaust? I know it's needed to for the engine light but I am waiting on an intake and a few other things before I tune it so if doesn't need to be 're done.
Old Mar 4, 2016 | 10:06 AM
  #399
Former Vendor
Thank you guys..
Wolftrk99: I believe 18".
parks450: If you're doing true dual exhaust I would recommend a full tune yes. You will probably need 3-5% more fuel up top on NA builds from what we have seen in the past.
Thanks
Sean
Old Mar 4, 2016 | 09:16 PM
  #400
Tim94gt's Avatar
12 Second Club
What is the length difference between the RCSB version and extended cab?
I'm looking to order one for my '05 2500HD Reg Cab w/ 8ft bed. Not sure which set-up I should run. My current set-up is dumping at about the same spot as the RCSB version, but I'd like to go a bit further back.
