Sorry another cam question.
Old Jun 26, 2013 | 08:36 PM
03sierraslt's Avatar
Like John said I would not go overkill as you are still trying to push a ECSB 4 x 4, 224/224 on a 112 would be a good cam. I would not go over a 228 with a 3200 stall in your truck, personally I think the 224 would be a better choice as everyone wants to overcam a heavy truck. Your exhaust setup is good so not much need to go with a cam that is exhaust bias. And your stock injectors will be maxed, I promise..... Stock injectors are damn near maxed on a stock 6.0
Old Jun 26, 2013 | 08:57 PM
Mangled03gmc's Avatar
Baltimore Whore
I can not believe that TSP specd that cam for you. Freaking retared. They must have over stock on them
Old Jun 26, 2013 | 09:10 PM
Zeke2007's Avatar
Thanks man so I should look into some injectors. What size should I look for??
I duno dude but thats what they told me torquer v2.
Old Jun 26, 2013 | 09:13 PM
Baltimore Whore
A set of 44lb marines would hold you over untill you went with Boost.
Old Jun 26, 2013 | 09:15 PM
Zeke2007's Avatar
Thanks man so I should look into some injectors. What size should I look for? I have stock tbss injectors for the tbss intake are they any bigger then what I have on my 4.8??
Old Jun 26, 2013 | 11:57 PM
grey matter 04's Avatar
13 Second Truck Club
224r gets my vote
Old Jun 27, 2013 | 01:04 AM
Vortec350ss's Avatar
Daily driving a cam and admiring its idle/high rpm power are 2 totally separate things. I would not go any bigger than mine is now on a daily. Don't get me wrong it has plenty of manners, but driving it EVERY DAY is really unforgiving for all the little quirks. I have a buddy with a trucker (216/224 with .551 lift on both sides on a 115+4 LSA) in his SSS. My cam makes more power, but not much more, and his has much better manners.
Take it from someone who has done EXACTLY what you say you are building now. First it was just mild cam, then it was mild cam that will possibly work with boost, now I'm boosted and want 11's. If I were doing it all over again I would want slightly more split, 6* or so and wouldn't go any bigger than mine in the exhaust side. In other words I would give up a hair of intake duration for slightly more manners and a little better suited to boost. Something along the lines of a 220/226 on a 114-115+4 with about .600 lift on both sides.
In my opinion the 6.0 does well with more split than the smaller engines because the intake valves are larger on the 317 and 243 heads.
Time and time again I see the smaller cams put up impressive times... I wouldn't even look at the 228r to be honest.
Old Jun 27, 2013 | 04:05 AM
I am running a little 217/229 and when I was NA for a year or so between blowers it ran great.
Old Jun 27, 2013 | 09:35 AM
Zeke2007's Avatar
Thanks guys for all the help its either gonna be the 220/224 or 224/224.
Thanks again
Old Jun 27, 2013 | 10:08 AM
I vote 220/224, but I would prefer more split if I was doing it again.
Look at Pat, 12* split and I have no doubt that it ran strong.
