Sooo i think its.
Old Sep 15, 2011 | 09:23 PM
kr1s's Avatar
Default Sooo i think its.
My ignition switch as to why i'm having all of my tranny problems, but is there any way to test my switch to make sure? and also where is IGN0 Located at?
Old Sep 15, 2011 | 09:49 PM
2007chevy5.3l's Avatar
Why do you think its the ignition switch?
Did you not try switcing PCMs? It sounds to me that its a PCM communication error...
Old Sep 15, 2011 | 09:59 PM
cdub81's Avatar
MAYBE, But you were not having these problems before the swap right? Iirc all these problems came up after the swap so the ignition being the problem is highly unlikely.
Old Sep 15, 2011 | 10:11 PM
kr1s's Avatar
No :/ Because remember i didn't use the pcm for the V6 I got everything complete. The guy at some transmission place told me to give that a try. Could a ground be doing this? If so does anyone have pictures or know where all the ground straps are? Cause the transmission worked twice for like 5min then went to **** :/ and started off in limp mode again. Could it be a bad PCM? Should i just invest in a Tune from the sponsors and get a new one? I'm getting super like ahhh
True, and yeah with the v6 i never had transmission problems. then here comes the 8 and it never worked right ever since.
Old Sep 15, 2011 | 10:31 PM
Dude all you have to do is reflash your v6 pcm with a stock v8 tune and your ready to go. You had no need to use a different PCM unit.. More than likely that avalanch PCM has some different calibrations in it that your truck isnt agreeing with.
Old Sep 15, 2011 | 10:36 PM
kr1s's Avatar
And i can re-flash it myself? :O Yeah cause i'm thinking maybe the avalanche was 4x4. Ummm... but aren't the PCMs different?
Old Sep 15, 2011 | 10:39 PM
Yes, if you have a tuning software.. 4x4 tune would throw yours off... No they all look the same, but the tune calibration stored in them is very different
Old Sep 15, 2011 | 10:45 PM
kr1s's Avatar
I thought the v8 had more ports because i need another slot to fire the Coils. ill look in a bit, and remember i have EFI LIVE, i have no idea how to do anything though
Old Sep 15, 2011 | 10:58 PM
Let this site be your guide EFILive Forum
Old Sep 15, 2011 | 11:03 PM
kr1s's Avatar
Thanks!
Mr. Chainsaw
Oct 18, 2015 08:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
dantheman1540
Jul 24, 2015 01:50 AM
blubaldmontess
Dec 13, 2008 06:12 PM
Spoolin
23
Sep 12, 2008 05:20 PM
