for some reason i can't build boost
Old Jan 14, 2005 | 10:16 AM
GREGGO's Avatar
Originally Posted by Naked AV
Didn't know you were Irish, Jim.
Ahhhh....laddy...that's what happens when me stay up dudrinking Killian's Idrish Redd!!!!
Old Jan 15, 2005 | 06:47 AM
KySilverado's Avatar
Originally Posted by gonzo 6.0
A limit strap may not be a bad Idea,just get it set so you dont get vibration.
I'm with this statement. I'm sure you're well beyond the design limits of stock motor mounts? What happens if one of these lets go during a run. I broke one once in my grandmothers 1973 dodge polaris. The whold damn motor and trans torqued up, dented the hood and then slammed back down hard enough to rock the car when I let off of it. Scared the **** out of me... Can't imagine what a high power motor mount break would do.
Old Jan 15, 2005 | 08:13 AM
parish8's Avatar
single digit dreamer
the way the stock mounts are built they cant come apart. i am a little worried about a starp puting too much stress on whatever bolt hole i use to hook it to. i would be taking all the stress that now goes to 4 beefy motor mount bolts(with extra casting on the block), to one bolt some place on the front of the block? doesn't make all that much sence to me.
i can see how it would help the wg/header live longer but i just need the correct header for that and that wont be a problem anymore.
Old Jan 15, 2005 | 11:09 AM
TieRod's Avatar
I wish the 8.1 motor mounts where like that. When I pulled the engine out my truck the driver side was riped in two. It did have a interlocking plate to keep the engine jumping around but it still pulled the rubber in two
ARC
57
Feb 21, 2022 10:54 AM
fastjweb
Aug 15, 2015 10:47 AM
USMCvet0311
Aug 14, 2015 10:28 PM
ZO6Ted
Aug 12, 2015 07:50 PM
05GMC4.8
Aug 7, 2015 09:55 PM
