some parts i gatherd for my 408 setup
Old Oct 24, 2006 | 06:58 AM
  #31
Rhino79's Avatar
9 Second Club
Then something is wrong with his setup. I had traction problems in 4hi with a larger cam that I "should" have less tq according to Rhino.
Dude I didn't ever say that you had less tq, you said a bigger cam would have more hp and a little less tq, maybe I've got his truck working better than yours.......dunno what else to say, ain't nothing wrong with his setup......is something wrong with running 7.80's in the 1/8th on motor in full street trim through full exhaust?
Old Oct 24, 2006 | 09:32 AM
  #32
bluecajun5.3's Avatar
11 Second Truck Club
should be a nice set up quik!
i haven't seen any #'s yet but they should be quite impressive i think .
Old Oct 24, 2006 | 10:21 AM
  #33
dirt track racer 81's Avatar
Originally Posted by Quik
the one in hte 6.0 is the TSP Tv2 112
whats the specs on it?? if your building this motor soon and plan on selling that and dont have it called for, id be interested in buyin it
Old Oct 24, 2006 | 10:52 AM
  #34
Texas Speed Torquer 2 232/234 .595/.598
Old Oct 24, 2006 | 11:12 AM
  #35
thanks on the specs
Old Oct 24, 2006 | 03:35 PM
  #36
Quik's Avatar
5 year bitches!
the Tv2 is staying in the 6.0... depending on if i go thru with my stang 6.0 project it will end up there or be sold entire to pay for the SSS
Old Nov 4, 2006 | 04:21 PM
  #37
Quik's Avatar
5 year bitches!
heres the 90mm TB i need to use with the L76 intake. theres room on the other side of the blade to smooth out and port match with the intake to make a smoother transition into the intake
Attached Thumbnails some parts i gatherd for my 408 setup-intimidator-001.jpg   some parts i gatherd for my 408 setup-intimidator-002.jpg   some parts i gatherd for my 408 setup-intimidator-003.jpg   some parts i gatherd for my 408 setup-intimidator-004.jpg
Old Nov 4, 2006 | 04:22 PM
  #38
Quik's Avatar
5 year bitches!
heres the SVO 42# injectors ill be using, also youll see i have them mocked up on a LS1 fuel rail onto the L76 intake. as you can see in hte one pic i have to tweak the rail to line up with the intake mounting holes and also to make spacers to make up the difference since the L76 is based off LS2 style injectors which are shorter, so my rail will sit slightly higher then on a LS1/LS6 intake
Attached Thumbnails some parts i gatherd for my 408 setup-intimidator-005.jpg   some parts i gatherd for my 408 setup-intimidator-006.jpg   some parts i gatherd for my 408 setup-intimidator-007.jpg   some parts i gatherd for my 408 setup-intimidator-008.jpg
Old Nov 5, 2006 | 10:08 AM
  #39
Stoichiometric's Avatar
Quick, which rocker arms are you going to run on the L92 head? You have an awesome set-up coming together .
Old Nov 5, 2006 | 10:27 AM
  #40
Quik's Avatar
5 year bitches!
i do believe the L92 rocker arms. i got my heads complete with rockers, and rocker arm plate. once i assembly the setup ill have more description. also i came across a 14bolt to hold the power woo hooo. and thanks i hope it puts good numbers down
