so i'm a retard
Old Nov 24, 2009 | 03:08 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
Default so i'm a retard
i dropped a torx head piece down in between the head & the intake manifold...it dropped into the little runners...now i'm rigging up a little magnet device to try and get it out...but let's say for ***** sake that i, god forbidding, don't get it out...will it go into the intake manifold or is there something preventing anything from getting in there...it dropped right where there's like little valleys on the intake side of the cylinder head...can get a pic if needed
in the valleys that you see there
Old Nov 24, 2009 | 03:18 PM
thunder550's Avatar
High on diesel fumes
If you can't get it out it will sit there and wait patiently for you to pull the intake manifold sometime in the future. I found an 8mm socket down there that I had lost about a year earlier one time. It was like Christmas in July
Old Nov 24, 2009 | 03:21 PM
OneQwikSS's Avatar
hahaha so it's not gettin sucked into the intake manifold correct?
Old Nov 24, 2009 | 03:23 PM
RandomHero's Avatar
LOL, think about it man, if there was a chance it could get sucked into the engine, you'd have much much bigger issues.
Old Nov 24, 2009 | 03:34 PM
scotthughes's Avatar
Banned Scammer
i wouldnt chance it. but who knows.
Old Nov 24, 2009 | 03:56 PM
RandomHero's Avatar
Like I said, if there's a hole in the intake big enough to suck a bolt inside of it, then the truck would already be running like ****.
Old Nov 24, 2009 | 03:59 PM
OneQwikSS's Avatar
that's kinda how i was thinkin...but i would like to be positive before i bolt it back up and risk it...tomorrow it'll be done and lookin pretty it gets dark here at 4:30 after daylight savings time & it's startin to get cold out...((bad painting weather)) i'll have pics for ya tomorrow guys
thanks
and like i said...so i'm a retard
Old Nov 24, 2009 | 04:03 PM
RandomHero's Avatar
Another example to think about.....let's say that the intake wasn't air tight and you went mudding. You'd be replacing a new motor every time water got underneath the hood.
Old Nov 24, 2009 | 04:18 PM
American Racing Headers's Avatar
Truck Premium Sponsor
it must that time of year. I had a ten mm bolt fall into the spark plug hole. I didn't believe it actually happened until we started the car. Needless to say the bolt did fall perfectly thru the hole... One crank and the piston was split OOPS...
Old Nov 24, 2009 | 04:21 PM
OneQwikSS's Avatar
lol OOPS is not a good word when you don't have the funding to fix the OOPS
