Smart people help me!
Old Dec 24, 2010 | 03:43 PM
youngbuck's Avatar
Default Smart people help me!
Well got the rpm gauge working, had to sauder in a resistor to the tach wire. Its working but way off how can I fix it? Using hp tuners thanks.
Old Dec 24, 2010 | 04:02 PM
mhotrodscooter's Avatar
Their should be a switch on the tach.. Which makes it 4,6,8 cylinders
Old Dec 24, 2010 | 06:19 PM
youngbuck's Avatar
a switch on the tach module? My tach gauge In the dash is v8 I kno cuz I took out a 350 . It reads just not right on the rpms like its out of sync. Very low reading even when I get on it.
Old Dec 24, 2010 | 08:11 PM
Sorry I thought you was using a aftermarket tach. Your resistor is holding to much back. You'll need to swap it out with one with less residence
Old Dec 24, 2010 | 08:56 PM
youngbuck's Avatar
Its a 1k 1/4 watt 5% tolerance, what would I need then?
Old Dec 24, 2010 | 09:28 PM
1Bear's Avatar
I don’t know which one you need, but I still feel you need to look at one of the TACH adapters to convert the signal, such as the ones below. I feel your ’93 cluster is looking for the typical 8cyl signal and your newer PCM is sending out a 4cyl signal. I would contact Autometer and ask them which one should work for your application.
http://www.autometer.com/cat_accesso...il.aspx?vid=99
http://www.msdignition.com/info.aspx...256&taxid2=267
Old Dec 24, 2010 | 10:34 PM
youngbuck's Avatar
So would the different resistor work? The tach is working just not reading accurate
Old Dec 25, 2010 | 04:17 PM
youngbuck's Avatar
Would a 5% tolerance b to much restricting on the signal making it work just not accurate?
Gadgetized
Oct 22, 2015 09:06 AM
Staggered 02
Oct 9, 2015 05:19 PM
JordanH
Oct 3, 2015 03:59 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
