Silverado SS has a clutch fan?
Adkoonerstrator
The clutch fan is actually better for towing. You can use LS1, LT1 or flexalite 282's on the SS though with nice results.
Please do a search on electric fans, it is kinda a over talked about subject in this forum.
Originally Posted by LOW2000
I wish someone would make a plug n play electric fan kit for our trucks that was both thermostatically controlled and had a switch override if you wanted it to be on. The things would sell like hotcakes.
The VSC controller that comes with the fan kit has 2 other connections that you could use. One turns the fans on all the time, the other turns them off regardless of operating conditions. Just wire a switch to the cab for these pins and you'd have full control.
You missed the part about plizzug and plizzay. No splice connectors, no wiring, no finding a good ground, plug n play.
