Silverado 4.8
Old Apr 21, 2020 | 05:55 PM
DanielB's Avatar
Registered User
Default Silverado 4.8
I have a 2012 silverado 4.8 with 180,000 miles on it still runs fine no oil leaks or anything but I'm thinking about getting another used motor to freshen up and do a mild build and put in it. So my question is what engine would work without changing alot of wiring etc. Could I put a 5.3 in it I'd assume the computer would just need reprogramming. If so what year engine would be best to get? Thanks in advance
Old Apr 21, 2020 | 06:06 PM
FFDP's Avatar
The most popular 5.3 in the generation you need are going to have AFM/DoD, so those engines would require that you delete those parts and the costs will rise because of the extra stuff you need to purchase to make it work.
If possible you'd really luck out if you found a 5.3 from a 2010-2014 Chevy Express or a GMC Savanna van, those came with 5.3 but did not come equipped with AFM/DoD or VVT (variable valve timing). That would make swapping one in cost less because you don't need the delete parts and would only require a cam/lifters if that was something you where wanting to change.
That 5.3 is labeled as the LMF engine. Examples on the AFM engines are the LY5, LMG and LC9.
Lastly no matter what the computer would be tuned, which you already said.
Old Apr 21, 2020 | 06:50 PM
arthursc2's Avatar
LY6 with a VVT delete cam/front cover
Old Apr 21, 2020 | 06:59 PM
DanielB's Avatar
Registered User
would I need a transmission also or would mine work with the 6.0?
Old Apr 21, 2020 | 07:03 PM
Drspencer's Avatar
5 Year Member
It’ll work with the 6.0. In fact, anytime people ask about swapping an engine, just go for gold! Ha. But really. It’s a truck. Put it to work.
Old Apr 21, 2020 | 11:13 PM
1994Vmax's Avatar
The LMF in the vans has VVT. Uses the same camshaft they use in the L20 4.8.
The only Gen iv 5.3 that came devoid of AFM and VVT was the LH8 used in the H3s and Colorado/Canyons. The subsequent LH9 that replaced the LH8 in 2010 has VVT. Good luck finding one of those though lol.
Old Apr 21, 2020 | 11:22 PM
FFDP's Avatar
Even better for him. A 5.3 with VVT would just slap right in there.
Old Apr 21, 2020 | 11:26 PM
1994Vmax's Avatar
Or just buy the run of the mill 5.3 with afm... swap the lifters, trays, cam, valley and timing cover from the 4.8 and voila... afm delete lol.
55chevyman
May 16, 2017 06:38 PM
jxnslotcar
Dec 20, 2011 08:33 AM
03silveradolt
Mar 9, 2008 12:25 AM
GMC_DUDE
Jul 26, 2007 03:23 PM
