View Poll Results: Which Headers? Pacesetters or LPP?
LPP
64.41%
Pacesetters
35.59%
Voters: 59. You may not vote on this poll
Should I Get Pacesetters or LPP?
Old Mar 2, 2009 | 06:11 PM
  #41
dug's Avatar
dug
Banned
Nope, I was just going to leave them uncoated. One reason I want the mild steel version, is theyre easier to weld. So if theyre problems with leaks by the ypipe it can be welded up.
TSP is jerking me around about canceling my order.
Old Mar 2, 2009 | 07:07 PM
  #42
TX Tahoe Z71's Avatar
True. But I would want to keep down the underhood temps, keeps the intake air and manifold cooler.
Old Mar 3, 2009 | 01:10 AM
  #43
luis06's Avatar
LPP is better I have them N my truck. They look great for 500 bucks with the Y-pipe it was worth it
Old Mar 3, 2009 | 02:31 AM
  #44
LS1TRUCKGUY's Avatar
who sells the LPP's? cant seem to find any
Old Mar 3, 2009 | 05:52 AM
  #45
BigCountryx's Avatar
lpparts dot com
Old Mar 3, 2009 | 09:14 AM
  #46
fredkj3's Avatar
i have the pacesetters.. got them like 2 years ago... no real problems.. the driver side one is a tight fit to get it in there.. if you have trouble than pull the spark plugs.. it gives you that extra little bit of clearance.. unless you undo the steering shaft which i didnt...... and also if your going pacesetters id order som 3" band clamps from jegs and not use the clamps that come with the kit... the ones that come with the kit get stuck and are a pain in the but to get loose when you have to pull that 4l60e down....
Old Mar 3, 2009 | 11:00 AM
  #47
dug's Avatar
dug
Banned
TSP cancelled my order. LPP look more enticing since I just found out they have free shipping. So its 500bux shipped to your door, headers and ypipe.
Hey Luis, how is the fit? Do you have any pics?
Old Mar 3, 2009 | 04:20 PM
  #48
Good call!
Old Mar 3, 2009 | 04:42 PM
  #49
AKAFRED's Avatar
you can weld s/s with a regular mig welder using regular wire... the weld may rust after time but no quicker than the same weld on a mild steel header..
i wouldnt reccomend doing a whole s/s exhaust system like this but if your just welding a s/s pipe to a galv pipe it will work no problems.
Old Mar 4, 2009 | 12:01 PM
  #50
luis06's Avatar
Heres the video/sound clip of an 04 silverado with LPP LT headers with magnaflow muffler.
http://www.youtube.com/watch?v=2OykCnK8C68
