Shorties?
Old Jan 22, 2007 | 05:30 PM
hammerhead's Avatar
Default Shorties?
Hi guys.
I was taking the EGR off the manifold the other day and a bolt broke off. Instead of trying to drill it out or weld over the hole, I was thinking of getting some shorties as a direct-replacement. Specifically, I was looking at Gibsons and JBAs (stainless). Does anyone have any experience with these? Can I use the later year version without the EGR & AIR tubes like these?:
http://www.supertruckusa.com/products/77595_309.htm
Thanks
Old Jan 22, 2007 | 06:55 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The JBA's are what I have but mine are the coated ones. Why not just put long tubes on and be done with it?
Old Jan 22, 2007 | 06:58 PM
gao8302's Avatar
I have gibson shorties. Very nice header but if i did it over again i would go with a set of pacesetter LT.
Old Jan 22, 2007 | 07:19 PM
hammerhead's Avatar
Mainly the cost. I'd like LT's, but I can get the shorties for a lot less & not have to get new cats and a new Y-pipe, right? I've got the same issue on the Camaro. That still has the stock manifolds but I was able to get the EGR tube out without breaking a bolt & I covered the hole with a steel plate.
Old Jan 22, 2007 | 08:33 PM
trever1t's Avatar
Price? JBA's are close to $600, Gibson's a little less, but yeah with cats and y-pipe the lt's would be be a little more.
Old Jan 22, 2007 | 09:29 PM
budhayes3's Avatar
PT's Slowest Truck
I have a set of used Gibson stainless shorties that I will be selling soon...but my recommendation is to get a good set of long tubes. I felt a noticeable difference when switching from the shorties to the StainlessWorks LT's and catted y-pipe.
Old Jan 23, 2007 | 08:38 AM
If you INSIST on using shorties, then why pay that much for Gibson or JBA? Summit Racing brand shorties...$145.00.....they do the same thing...
Old Jan 23, 2007 | 10:00 AM
SSmikeSS's Avatar
Those can't be stainless. IMO you should get stainless steel.
But, you could always buy 2 or 3 sets of those for $145 and still be cheaper than some good ones
Old Jan 23, 2007 | 10:26 AM
LARRY01Z28's Avatar
i have eldelbrock shorties, nic eheaders, good fit, but if i had it to do over id get pacesetters or OBX long tubes
Old Jan 23, 2007 | 10:43 AM
flossinon_24s's Avatar
ive got a few sets on factory manifolds, if you need one.
flatblack83
Jan 3, 2026 07:10 PM
FlyingLow
Nov 24, 2015 10:05 AM
5.3Caprice
Nov 7, 2015 08:56 PM
Cowboy Tom
11
Sep 16, 2015 09:35 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
