shortbelt
Old Apr 29, 2007 | 01:25 PM
99LoweredSierra's Avatar
Default shortbelt
I got mine on and tested it! I went with the one 60in so it by passing power steering and alternator. Going to see how much it makes on the dyno this week.
Old Apr 29, 2007 | 01:49 PM
454SuperSport's Avatar
i wouldn't bypass the alternator.
Old Apr 29, 2007 | 01:54 PM
Derek @ EDO's Avatar
FormerVendor
You will be fine bypassing the ALT, many have done it without issues!
be sure to post up the results
Old Apr 29, 2007 | 03:50 PM
ok i will!
Old Apr 29, 2007 | 03:57 PM
adrenalinep's Avatar
Make sure you have a good battery. Ive made 4 passes at the track before with it w/no problems . We tried it on a buddies truck this fri. and it lost power on the first run couldnt even do a burn out ( no power to the coils). His truck s an 04 and still had the original battery.
Old Apr 29, 2007 | 04:17 PM
exactly why i suggested against it, that 1/2hp you get from bypassing it isn't going to matter if your pcm shuts down at half-track from weak voltage
Old Apr 29, 2007 | 05:06 PM
I have good voltage! My battery is pretty new!!
Old Apr 29, 2007 | 06:05 PM
youll be fine
Old Apr 30, 2007 | 06:37 PM
Check my dyno results out!
Luke03
May 8, 2010 11:31 PM
99LoweredSierra
May 8, 2007 12:51 AM
adrenalinep
Feb 13, 2007 10:02 PM
Derek @ EDO
Feb 4, 2007 06:21 PM
derek_silvy
Feb 10, 2005 08:18 PM
