short belt?
Old Jul 21, 2008 | 11:03 AM
chevrolet all the way's Avatar
Default short belt?
ive heard this will shave off around .2 off your 1/4 and its so simple and cheap, but i dont know the routing of it or length. also is it actually a good idea?
Old Jul 21, 2008 | 12:28 PM
regency's Avatar
make a v pattern: over the tensioner, under the waterpump, over the alt., and under the crank!!! and remove the a/c belt too!!! i think its worth a couple tenths. i havnt done it yet but i have everything to do it and im just waiting
Old Jul 21, 2008 | 01:15 PM
sweet thnak you very much, you know a length or do i just need to measure it?
Old Jul 21, 2008 | 02:21 PM
TXsilverado's Avatar
that routing only works if you have an ASP underdrive pulley. if you do not have an underdrive pulley you can use this routing.
Old Jul 21, 2008 | 03:48 PM
no alternator? just curious, why wont it work withouth the ud pulley?
Old Jul 21, 2008 | 05:17 PM
sprayed8's Avatar
Also curious, is it because there is not enough clearance between the water pump pulley and the crank to fit the belt if you dont have and UD?
Old Jul 21, 2008 | 08:08 PM
bluecajun5.3's Avatar
11 Second Truck Club
b/c with the stock crank pulley, the belt rubs against the p/s pulley.
Old Jul 21, 2008 | 08:48 PM
regency's Avatar
correct!!!!!
Old Feb 3, 2009 | 02:38 AM
slidesquad's Avatar
whats the part number for the yellow path belt?
AdaMax
May 16, 2016 11:35 PM
gmcyukon
Oct 5, 2015 06:20 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
murderedSS
Sep 27, 2015 10:16 PM
