shifts acting up
Old Aug 17, 2004 | 12:35 PM
WaitinToDrag's Avatar
Default shifts acting up
my truck has been actin up a little bit at like 3/4-WOT. at WOT there seems to be a hesitation to accelerate....then it catches for a sec..then the rpms shoot up to like 5600 and just revs...then drops back down. its kinda doin the same thing on the low end also...just feels like somethings not catching?
im boosting like normal and everything seems/sounds fine under the hood. maybe TC goin out ot tranny bout to take a poop?
please advise
chris
Old Aug 17, 2004 | 01:10 PM
James B.'s Avatar
Clutches, probably the third/fourth set. I'm guessing it's happening in third or/and Overdrive. The best replacement seems to be the RayBestos Z-Pak.
Old Aug 17, 2004 | 03:41 PM
Mine did the same thing luckly it was still in warrenty, the dealership told me that the 2-4 band in the trans was almost gone! When it would shift it would keep slipping until it would catch. I would say it is time for a rebuild.
Old Aug 19, 2004 | 04:00 AM
what is the raybestos z pak?
Old Aug 19, 2004 | 10:42 AM
James B.'s Avatar
The ZPak is a replacement 3-4 clutch set where each plate has friction material on one side and steel on the other instead of alternating friction and steel plates like conventional clutch packs. It handles greater heat and has better resistance to warping (coning) than conventional clutches.
Take a look:
http://www.raybestospowertrain.com/p...ures_zpak.html
Blwn99x
Mar 24, 2023 11:14 AM
RustyD
May 23, 2016 07:04 PM
Wolftrk99
Dec 3, 2015 08:12 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 06:27 AM
