??service 4wd Message??
Old Jun 27, 2005 | 08:50 AM
TG02Z71's Avatar
Default ??service 4wd Message??
Had this message come up breifly Saturday upon start up.
Anyone know what this might be linked to?
The light did not come up again.
About a week ago when rotating my tires I noticed my left front rim had allot more crud built up in it, other than brake dust that is.
Old Jun 27, 2005 | 09:08 AM
I Dont Know What It Is But Mine Has Come On A Couple Of Times Also. Mine Is Push Button 4wd And When It Came On It Wouldn't Let Me Shift Into 4wd At All. But I Killed It And Cranked It Back Up And It Worked Just Fine. Weird!
Old Jun 27, 2005 | 09:25 AM
Black04HD's Avatar
Same thing here...It came on about 2 or 3 months ago as soon as i started the truck for about 20 minutes one day even while i was driving. When I got home, i restarted and it still wouldn't go off, so i did some stuff around the house for an hour or so, and went back out and restarted again, and everything was fine. I have used the fourwheel drive about 4 to 5 times since and it still works great. I have pushbutton 4x4 too and it also wouldn't let me shift into fourwheel drive or anything due to the fact that there was not light to show what gear i was in (2, 4Hi, or 4lo). But everything is working fine now so i wouldn't worry about it too much.
Old Jun 27, 2005 | 09:39 AM
dewmanshu's Avatar
Moderately Differentiated
not sure about the 2004 guys but the first guy is 2002...the 99 to 2002's are known for having a bad switch here and there. (Mine did). The light will come on when you have hit whatever mileage needed to warrant a servicing...but it shouldn't affect the ability to go into 4wd. The bad switch will obviously affect this ability. You guys still in warranty? (I am sure the sts doesn't have a chance for warranty unless it is definitely just the switch)...mine was fixed under warranty...when it was still under warranty.
Old Jun 27, 2005 | 11:02 AM
TG02Z71's Avatar
No warranty left here!!
And your right as soon as they see the turbo under there all help from the stealership would be off!!
Old Jun 27, 2005 | 11:10 AM
dewmanshu's Avatar
I just noticed you have a "freshly built" 60 as well. They won't take kindly to that either. Ah for the hell of it buy a switch from a junk yard or something, might help. The button only cost me from a service shop 55 bucks new. Part number for the 2000 was GM 15709327. Hope that helps and that's all thats wrong.
Old Jun 27, 2005 | 11:21 AM
The 4wd switch in the dash is poorly constructed and will eventually light your service 4wd warning on your dash unless gm decided to redesign it.
As i recall the switch costs about $40-$60 at a dealer however if you can solder well you can just fix it yourself, the problem lies in the solder points at the connection pins.
This is an easy fix especially since the dash just snaps apart no tools other than fingers and care required.
Old Jun 27, 2005 | 11:46 AM
TG02Z71's Avatar
Hey thanks man, I can solder so guess i'm in luck. WoooHOOO
Old Jun 28, 2005 | 08:30 AM
sd155racer's Avatar
Bingo - switch
thompson
Dec 27, 2017 06:48 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
RustyD
May 23, 2016 07:04 PM
Staggered 02
Oct 9, 2015 05:19 PM
Closer_2001
Sep 24, 2015 09:15 PM
