Service 4wd Dummy Light?
Old Jan 8, 2002 | 02:28 AM
KTamez's Avatar
Default Service 4wd Dummy Light?
What is supposed to be checked/changed here? Gear oil in transfer case? Beyond that how can I get rid of the damned light.... The manual just says take to dealer (course it leaves out the "Write Check" part.
Thanx in advance.
Old Jan 9, 2002 | 12:50 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Default Re: Service 4wd Dummy Light?
It means that a failure code has been stored. I've had to replace either the mode selector switch (the part with the 4wd buttons <img src="gr_stretch.gif" border="0"> ), and sometimes the encoder motor, which is located on the transfer case. If you had the number of the actual failure code I can probably tell you where to start. You would probably have to get it to a dealership to pull the code.
Old Jan 10, 2002 | 12:34 AM
KTamez's Avatar
Thanx!
I tried to pull a code with my Snap-On scanner with no luck. The truck is still under bumper-bumper so I suppose I should just take it in. I just didn't want to take it in and have my local Chev dealer tell me "Ya need to change the fluid, that'll be $65.18 for the diagnosis". Lets just say the local Chev dealer is like that. <img src="gr_sad.gif" border="0">
Choda
Jun 5, 2025 06:43 PM
carid
Oct 28, 2015 08:24 AM
Tydriver
45
Oct 23, 2015 09:19 PM
bluestang50
Sep 21, 2015 08:36 AM
fortune46x
Sep 16, 2015 08:18 AM
