seriously confused
#21
hog, thanks alot for the informative post. do you suggest I do the cats just like in this picture? I mean there is absolutely no way (the way i see it) to get equal lengh pipes before they hit an h-pipe or x-pipe.
Also, if I end up doing this, should I stagger the mufflers or could the mufflers be placed at the same location on both pipes?
Last but not least, whats the best location to place the cats, not for the sake of emissions but performance wise by acting as a termination for the collector length tune?
#22
im not making near the hp you are. im about 360hp and going from the stock 87mm to a 90mm made my truck run better. im not talking about 10+ hp or anything but with my cam the stock 87mm would sometimes take 2 times to try to crank my truck and after switching to the 90mm it starts right up. so it needed the extra air.
#24
#25
2) So far as muffler placement, its best to place them as far back as possible. If you get them far enough away their role in actual exhaust tuning is minimized allowing you to place them in a non-staggered position.
3) For emissions the ideal place for a cat is as close to the cylinder as posible for a quick light off.
For performance, you can take a wax crayon and run it along your headpipes. The point at which the crayon is burned off (before the area where the crayon mark remains)is where you place the H-pipe.
I did some more research on collector termination and if the cats effective internal volume is close to the pipe diameter that cats can be placed right at the ends of the collectors and not affect pulse tuning in a major way.(the small bullet cats would be an example). If you use a cat with a larger volume, this will end up being your collector termination point.
This post has some great reading.(PECOS posts specifically)
GM Performance :: View topic - Started Long-Tube install...
Hope this helps.
peace
Hog
TAPyvehc93
Sep 14, 2015 01:22 PM
