Convert MAF IAT to stand alone IAT
Old 10-23-2011, 09:21 PM
TheGreat4.8's Avatar
Default Convert MAF IAT to stand alone IAT
I have a density tune on my 01 sierra 4.8 and the only reason i keep my MAF is for the IAT, can i use a ls1 style IAT with my setup with original wiring?
reason for asking is my MAF has been looking pretty pitiful for a few years but i kept it anyway and tonight (cold air) i had an extremely lean running motor that started 10 minutes into a light throttle drive, it wont idle at all and has lean knocking now.
Old 10-23-2011, 09:38 PM
black04's Avatar
Yes you can use the ls1 sensor or msd makes one as well
Old 10-23-2011, 10:27 PM
Nice, so does anybody have any part numbers or car models i can use at a local parts store? I'm kinda in a hurry to get this figured so ordering online is too slow.
Old 10-24-2011, 08:23 AM
robbyredneck's Avatar
if your turbo and want a screw in one on the cheap. go to your local parts store and get a 87 grand national one. then go to your yard and clip any loose modern gm iat pigtail that fits. then look at your maf and you can easily follow which two wires go to the iat. clip, splice, and rock.
Old 10-24-2011, 08:32 AM
I have a gauge for that
Atomic's Avatar
IAT Sensor MSD 2030 $31
Old 10-24-2011, 08:37 AM
KHester84's Avatar
Just curious, how is removing MAF and moving the IAT sensor elsewhere going to help with your lean cruise and idle? Or are you just trying to remove an unnecessary intake component, then get it retuned?
Old 10-24-2011, 10:43 AM
Well if my MAF is dead then i have no IAT considering its built in to the MAF, and it is pointless for me to run a MAF if i don't need one with SD.
Old 10-24-2011, 10:59 AM
But thanks for the replies, honestly I"m more worried about the new sensor working exactly the same as the stocker as far as tune wise. I'm not in any position to be getting a retune considering my tune is 400 miles away
Old 10-24-2011, 12:48 PM
KHester84's Avatar
Just make sure the output scaling is the same on the new sensor as the old one, should be OK.
Old 10-24-2011, 01:00 PM
Zachsb3's Avatar
i used bwd WT3036 $17 and available at most parts stores.
Quick Reply: Convert MAF IAT to stand alone IAT
