?'s on ELECTRIC FAN and ASP pulleys
Old May 8, 2002 | 04:31 PM
Default Re: ?'s on ELECTRIC FAN and ASP pulleys
Thanks Guys for all your input. Lokks to me like the fan and pulleys is a good idea. The only thing problem is the pulleys are on back until who knows when. The fan has me a little hesitant though. Is there a fan out there that will allow me to use the stock shroud?
Do you guys know what the rating on your fans are as far as CFM:
How much CFM should I be looking for?
Which is better?
Flexlite twin fan pushing 1800 CFM for $300
Flexlite twin fan pushing 5500 CFM for $500
Single fan pushing 1000 CFM for about $100
Does anyone know stock CFM rating
Thanks,
Old May 8, 2002 | 07:16 PM
yellowls1truck's Avatar
i have had my setup for a year now with no problems. i am using a perma cool adjustable relay, derale 16 inch s-blade fan, asp pullies and i use the stock fan shroud. it was actually pretty easy to hook it all up, comes on automatically.
Old May 8, 2002 | 11:44 PM
graygmc's Avatar
fast4.8:
could you send me a diagram too. both richards have told me ways to hook the fans up, but it wouldnt hurt to look at a third. thanks.
Old May 9, 2002 | 12:59 AM
GREGGO's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by YUKONTURTLE:
<strong> Since we are on the subject about the electric fans, do you have to be electronically inclined to install one or will it be a simple bolt-on just by following the instructions?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That depends on if you under stood what oxidizr just wrote <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> . If you go with a kit that is made for the truck or a universal kit you should be fine with the instructions. If you go the cheaper route like some of us did by using the LT1/LS1 fans, I can send you a diagram that should get you through it.
wickedRCSB
Oct 30, 2015 09:45 PM
CD82
Oct 23, 2015 07:32 AM
Lthompson
Oct 2, 2015 12:45 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
