???'s differences in 5.3
l59 has a different style fuel pressure regulator, and different coils also, im not sure about the sonnectors, but i think the regulator is adjusted to allow more fuel to bypass it.
9 Second Club/LS1TECH Sponsor
Sure. You can use Edit to adjust for the bigger injectors. Then you need to change the connectors on your harness to fit the flex fuel injectors.
Send your harness up, we'll put the right connectors on it.
There's no reason you can't take advantage of the bigger injectors if you want to. Especially if you have a lot of performance mods planned for the future.
Originally Posted by 2000_Silverado_SS
So it would be best to use my LM7 intake and fuel injectors on this L59 motor. That sucks that I will not be able to take advantage of the larger injectors. Will my LS1edit solve any of these issues with this different style engine?
05GMC4.8
08-07-2015 09:55 PM
