???'s differences in 5.3
Old Jul 17, 2004 | 11:43 PM
hink9's Avatar
l59 has a different style fuel pressure regulator, and different coils also, im not sure about the sonnectors, but i think the regulator is adjusted to allow more fuel to bypass it.
Old Jul 18, 2004 | 12:07 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Sure. You can use Edit to adjust for the bigger injectors. Then you need to change the connectors on your harness to fit the flex fuel injectors.
Send your harness up, we'll put the right connectors on it.
There's no reason you can't take advantage of the bigger injectors if you want to. Especially if you have a lot of performance mods planned for the future.
Originally Posted by 2000_Silverado_SS
So it would be best to use my LM7 intake and fuel injectors on this L59 motor. That sucks that I will not be able to take advantage of the larger injectors. Will my LS1edit solve any of these issues with this different style engine?
Old Jul 18, 2004 | 11:07 AM
marc_w's Avatar
Speartech is right on... Sounds like you actually lucked out with this motor.
In HP Tuners, setting up the motor for different injectors is pretty easy.
Old Jul 18, 2004 | 11:48 AM
gonzo 6.2's Avatar
Why doesnt someone make an adaptor connector to go between the L59 injector and the Lm7 harness?
Old Jul 23, 2004 | 06:45 PM
Speartech's Avatar
There's no available mating connector for the injector connector on the LM7 harness. If there were, you could make a nice adapter harness.
Bumpers
Aug 4, 2024 09:44 PM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
smit2732
Jul 19, 2015 01:43 PM
